It is currently Sat Nov 07, 2026 3:11 pm
 Post subject: Post Gimp-3.0 Scripts and Plugins Here
PostPosted: Fri May 16, 2025 7:25 pm  (#1)
If anyone wishes to post 3.0 resources.
This is the place to do it.
:jumpclap
 Post subject: Re: Post Gimp-3.0 Scripts and Plugins Here
PostPosted: Fri May 16, 2025 9:11 pm  (#2)
:jumpclap
Excellent!
This should make things less confusing. :bigthup :hi5
PostPosted: Fri May 16, 2025 9:44 pm  (#3)
Moderators have moved I believe all the previous Gimp-3.0 scripts and or plugin topics. If anyone see's one out of place, just PM a moderator to move it. Just click on one of the light blue names in this forum. And then click on PM and send your message and the URL to the topic that needs to be moved. :bigthup
Thanks!
PostPosted: Sat May 17, 2025 8:11 am  (#4)
Thanks to Wallace for the work he did.
This should also be moved:
Resynthesizer for GIMP 3.0 RC2 Win64
viewtopic.php?f=7&t=21535
Beautify Plug-ins for GIMP 3.0 RC2(include simple-border)
viewtopic.php?f=9&t=21541&start=0
PostPosted: Sat May 17, 2025 9:15 am  (#5)
Thanks MareroQ.
I moved those topics you mentioned to this forum.
:hi5
The suggestion to create this specific forum was offered to us by Rod.
This suggestion seemed a no-brainer to me and to the rest of the admin as well.
PostPosted: Sat May 17, 2025 11:25 am  (#6)
Thank you!
PostPosted: Sat May 17, 2025 12:46 pm  (#7)
Jappaloe63 wrote:
Thank you!
:hi5
