It is currently Sat Nov 07, 2026 3:11 pm
 Post subject: GEGL RGB Glitch GIMP plugin
PostPosted: Wed Jul 23, 2025 8:00 pm  (#1)
We have a new GEGL plugin that makes a rgb glitch effect by moving the Red Green and Blue channels independently.
A general rule when using this plugin is try to make sure two sliders are equal opposites. In example if Red Horizontal is 9
Blue horizontal should be -9 (negative 9) try to balance all of them out that way as that best makes a stereo glitch effect. There is also a slider that attempts to removing glitching on the borders but it isn't perfect.
Fun Fact if you look at the code you will realize this plugin has a extremely complex GEGL Graph, perhaps one of the most complex graphs I ever wrote.
This plugin internally calls `gegl:inner-glow` that ships with GIMP 3.
Download code and binaries here
rgb_glitch_SourceCode.zip [4.51 KiB]
Downloaded 208 times
rgb_glitch_linux_binaries_gegl_plugin.zip [6.64 KiB]
Downloaded 230 times
rgb_glitch_windows_binaries_gegl_plugin.zip [32.17 KiB]
Downloaded 246 times
THEN RESTART GIMP AND GO TO GEGL OPERATION and look for "RGB Glitch" filters>Artistic>RGB Glitch it will be in the main menu in Selection in Gimp 2.99.16+ but 2.10 users will have to go to GEGL operation > GEGL Effects Continual
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
More Previews
You can test without installing by putting this syntax into GIMP's GEGL Graph filter
id=beforestart gegl:dst aux=[ ref=beforestart
id=start
src aux=[  ref=start multiply aux=[ color value=#ff0900  ] ]
id=red
src aux=[  ref=start  multiply aux=[ color value=#00ff00  ]  ]
id=green
src aux=[  ref=start  multiply aux=[  color value=#0000ff   ]   ]
id=blue
color-overlay value=black
screen  aux=[ ref=red  translate x=6 ]
screen aux=[ ref=green  ]
screen aux=[ ref=blue translate y=-6  ]
id=glitchfinal
dst-in aux=[ ref=beforestart ]
crop aux=[ ref=beforestart ]
id=a over aux=[ ref=a
inner-glow value=white radius=20 opacity=2 grow-radius=1
multiply aux=[ ref=beforestart ]
Enjoy and feel free to leave feedback :paint
 Post subject: Re: GEGL RGB Glitch GIMP plugin
PostPosted: Sun Mar 22, 2026 12:18 am  (#2)
This plugin now works on Windows GIMP 3.0.8 and 3.2 and hopefully beyond
The code is the same as above but the Windows build updated to use gettext so it works on GIMP 3.2
rgbglitch_windows_binaries_gegl_plugin.zip [45.96 KiB]
Downloaded 149 times
LOCATION TO PUT BINARIES
If you want the source code just look above.
