It is currently Sat Nov 07, 2026 7:05 pm
 Post subject: trying to batch process image using filter on gimp command notpad
PostPosted: Thu Sep 04, 2025 4:11 am  (#1)
Hi, can you help me, im trying to batch process some photos, Idea is so I can have lots of photos in one folder and use a programme or something maybe made specifically for me so I can batch process images in folder into a specific folder called in filters the extended filter contour , its called super pixel. Can anyone help me with this please, Im lost. I see says can copy command to clipboard, jut just dont know how to batch process that command.
Any help advice really appreaciated.
Thanks
Charles
 Post subject: Re: trying to batch process image using filter on gimp command notpad
PostPosted: Thu Sep 04, 2025 5:32 am  (#2)
Sounds like you need the batcher plugin for gimp - this is for version 3
https://github.com/kamilburda/batcher
