GIMPhelp wrote:
I am on Windows 10 and would like to batch watermark a large number of images. I have experience with GIMP but not with GIMP automation or batching.
This is with GIMP 3.0.6 and G'MIC-qt.
The G'MIC-qt watermark filter within GIMP works very nicely when used manually.
I installed Batcher with the intention of automating the G'MIC-qt watermarking process.
Batcher within GIMP seems to work fine (basic functions, I'm not familiar with it).
However, the problem is Batcher does not 'recognize' or 'find' any of the G'MIC-qt filters (including the watermarking filter). In other words, the G'MIC-qt filters do not show up in the Batcher menus.
Is this a known problem, or have I installed Batcher incorrectly?
Please help. Thank you.
Some interactive gmic filters will not work but most will. Goes like this:
Start off with an image in Gimp. Apply a filter. Copy the filter command string.
Start Batcher - you can use export images or export layers or edit layers - up to you and depending on image(s)
Go to Add Procedure -> Custom Procedure -> Plug-ins and find plugin-gmic-qt
Set the input mode to 1 and paste-in the command string.
Add then run Batcher to process the selected files.
@Wallace: for Gimp 3
https://sourceforge.net/projects/gimp3- ... s/general/ ofn3-export-layers
