It is currently Sat Nov 07, 2026 3:11 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: GEGL pipes (golden pipe wallpaper fun)
PostPosted: Mon Jan 19, 2026 3:09 am  (#1)
Please test this plugin on GIMP 3 RC2 on both Windows and Linux
linux_metalpipes.zip [8.36 KiB]
Downloaded 166 times
windows_metalpipes.zip [33.15 KiB]
Downloaded 209 times
pipes_source_code.zip [4.86 KiB]
Downloaded 164 times
We have a new plugin called GEGL pipes. Its the second GEGL plugin of 2026 because I never released the first one yet :oops:
I need to know if it works on GIMP 3.2
LOCATION TO PUT BINARIES
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
Linux(Flatpak includes Chromebook)
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
If you compile it from source lemme know but I'd prefer to know if the binaries work
The Linux Binary was compiled against GEGL 0.4.67
The Windows Binary was compiled against GEGL 0.4.48 quasi-mysys2
both on X64 Fedora Linux
Look in Filters>Render>Fun to find it or search "pipes"
then restart GIMP and go to "GEGL operation" to find the new plugin
Have fun everyone, its really important I know if this works in RC2 :coolthup :jumpclap
 Post subject: Re: Test if this Plugin works on GIMP 3.2RC2 onward (GEGL pipes)
PostPosted: Mon Jan 19, 2026 3:10 am  (#2)
and if it doesn't work consider telling me what the terminal says
PostPosted: Mon Jan 19, 2026 3:57 am  (#3)
Alway up for a test ;)
Kubuntu 24.04 / Gimp 3.2.0 RC2 (appimage from gimp.org) and it works ok.
PostPosted: Mon Jan 19, 2026 4:19 am  (#4)
Thank you for the new filter.
Unfortunately, it doesn't work for me in Gimp 3.2 RC2 (Win10).
gegl-0.4\plug-ins\metalpipes.dll: The specified procedure could not be found.
Works in Gimp 2.10.38 and 3.0.6.
Also works in RasterFlow :yes
PostPosted: Mon Jan 19, 2026 5:05 am  (#5)
In rasterflow its missing many gimp: nodes.
My plugins work on GIMP 3 RC2 on Linux compiled against GEGL 0.4.62 and or 0.4.67
the problem is Windows compiled against 0.4.48. I don't know how to get GEGL 0.4.67 on Windows, but it could also be the possibility Windows is blocking something, innfact I already knew they worked on RC2 Linux I just wanted to double check.
Try to compile GEGL on Windows using this
https://github.com/HolyBlackCat/quasi-msys2
PostPosted: Mon Jan 19, 2026 5:06 am  (#6)
Greatly appreciated, Yeah its a Windows thing, It needs to be recompiled for Windows and I don't know how to do it.
 Post subject: Re: GEGL pipes (golden pipe wallpaper fun)
PostPosted: Mon Jan 19, 2026 1:26 pm  (#7)
Another nice filter!
It runs smoothly here, even in AppImages Gimp 3.2 RC2 from gimp.org and from ivan-hc Continuous GIT.
Many thanks contrast_ !
Gimp 3.0.8
Gimp 2.10.38 AppImage
OS: Linux Mint 21.3 Virginia based on Ubuntu 22.04
PostPosted: Mon Jan 19, 2026 1:32 pm  (#8)
I compiled pipes.c with gegl-0.4.62 (this is my msys64/mingw64 version installed for Gimp 3.0.4).
It still doesn't work.
I updated Gegl to version 0.4.66-1 and recompiled.
The filter still doesn't work.
PostPosted: Mon Jan 19, 2026 2:27 pm  (#9)
What does it say in the cli?
PostPosted: Mon Jan 19, 2026 3:27 pm  (#10)
Do his plugins work (Flatscrew)?
also try this really simple plugin via compiling, this is as simple as they get if this doesn't were doomed
msi_gegl_plugin.zip [3.75 KiB]
Downloaded 158 times
It makes no sense they work fine on Linux
PostPosted: Mon Jan 19, 2026 3:58 pm  (#11)
Tell me if this works on Windows its 0.4.48 but Grok attempted to "fix it"
This is a DLL file precompiled
Downloaded 155 times
He and DeepSeek both said its possible windows interprets GEGL graphs in a different way
PostPosted: Tue Jan 20, 2026 1:05 am  (#12)
This latest version also didn't work in Gimp 3.2 RC2 for Win10.
For testing purposes, I downloaded:
https://github.com/flatscrew/plugins-linux-beaver
The compilation went smoothly, but the filters don't work in Gimp 3.2 RC2.
Those included in the RasterFlow installer work in Gimp 3.2 RC2 for Win10.
My conclusion is that my compilation environment is incorrect.
I couldn't find any information on how Flatscrew compiled plugins-linux-beaver.
PostPosted: Tue Jan 20, 2026 6:39 pm  (#13)
Does he put them in the same directory that you put your plugins in, or a different one? We have to figure out what he is doing.
I ran vimdiff and his plugins are the same code outside of a few changes he made to irrelevant category areas in some of them. So either its the compilation environment or he puts them in a different folder. They work on Linux atleast with no issue.
PostPosted: Wed Jan 21, 2026 9:21 pm  (#14)
Hi contrast_, Just to mention Imgur blocks all access from the United Kingdom so anyone in the UK won't see the images you put in post #1.
PostPosted: Sun Jan 25, 2026 2:16 am  (#15)
Ok, I'll use a dif image host. Can someone test if my plugins work on GIMP 3.0.8, (Linux and Windows) they should as nothing changed. I'm just too lazy to check
PostPosted: Mon Jan 26, 2026 11:52 am  (#16)
@_contrast , 'golden pipe' whistles here as a golden pipe!
Gimp 3.0.8
PostPosted: Tue Jan 27, 2026 6:40 am  (#17)
Well at least we can still use them in Windows 11 Gimp-2.10.38 RC versions. :)
MareroQ, i tried PMing you about Rasterflow. Can you tell me how you compiled it?
Thanks!
PostPosted: Tue Jan 27, 2026 3:47 pm  (#18)
Thanks!
2.10.38 isn't non-destructive.
Does pipes work on Windows on 3.0.8?
PostPosted: Tue Jan 27, 2026 3:50 pm  (#19)
Whatever the hell is going on is confirmed to be a compilation enviorment issue. They work on Windows but I am compiling them in a unallowed way. I think the binaries need to be signed or something, but I'm just guessing.
Perhaps Grok and DeepSeek can figure it out. Though I can't test because I don't have Windows.
PostPosted: Wed Jan 28, 2026 1:37 am  (#20)
Hi Rod,
The Windows installer version RasterFlow-0.1.5-Setup-win64.exe doesn't work for you?
https://github.com/flatscrew/rasterflow ... tag/v0.1.5
RasterFlow (v0.1.6) compiles without problems on msys64/mingw64 according to the author's guide.
Only libgtkflow and libgflow need to be compiled from source, while the remaining required dependencies can be installed using pacman:
https://packages.msys2.org/search
