It is currently Sat Nov 07, 2026 7:04 pm
 Post subject: [New Plugin] Photoshop-style Layer Workflow (Group, Ungroup, Merge)
PostPosted: Fri Feb 06, 2026 3:34 am  (#1)
I'm Yousei3, a GIMP user from Japan. I recently moved my creative environment to Linux Mint, and while I love GIMP, I found myself missing some of the specific layer workflows I was used to in Photoshop.
To bridge this gap, I’ve developed a small suite of Python plugins: "Photoshop-style Layer Workflow".
- Group Selected Layers: Groups only the layers you have currently selected.
- Ungroup Layers: Unpacks layers from a group and cleans up the empty group layer.
- Merge Selected Layers: Merges selected layers into a new single layer while keeping the originals (non-destructive style).
Installation (for GIMP 3.0 / 3.2)
1. Download the `.py` files.
2. In your GIMP plug-ins directory, create a separate folder for each plugin with the same name as the file :
plug-ins/merge_selected_layers/merge_selected_layers.py
plug-ins/group_selected_layers/group_selected_layers.py
plug-ins/ungroup_layers/ungroup_layers.py
plug-ins/
 ├── group_selected_layers/
 │       └── group_selected_layers.py
 ├── merge_selected_layers/
 │       └── merge_selected_layers.py
 └── ungroup_layers/
           └── ungroup_layers.py
3. Ensure the files have execution permissions (`chmod +x`).
4. Restart GIMP.
It would be more convenient to set up shortcut keys.
A right-click menu has also been added to the layers.
A Note on Development: I am still a beginner at Python. To bring these ideas to life, I collaborated with AI (Google Gemini) to write and refine the scripts. They have been tested and are working smoothly on my Linux Mint system.
I've shared the code on GitHub. I would be very happy if you could try them out and give me any feedback or suggestions!
GitHub Repository: /yousei3/gimp-photoshop-layer-workflow
Thank you for this wonderful community!
⚠️ I've attached the plugins as a ZIP file for your convenience. (update v1.1)
File comment: Updated to v1.1: Fixed README description for Merge, added Windows paths, and enabled right-click menu.
gimp-photoshop-layer-tools.zip [5.6 KiB]
Downloaded 206 times
 Post subject: Re: [New Plugin] Photoshop-style Layer Workflow (Group, Ungroup, Merge
PostPosted: Fri Feb 06, 2026 2:06 pm  (#2)
Yousei3D wrote:
Hi everyone,
What’s included:
GitHub Repository: yousei3/gimp-photoshop-layer-workflow
Thank you Yousei3D. Are these for Gimp-3.0 or Gimp-2.10 versions?
Never mind i see they are for Gimp-3.0.
They also for your information work in Gimp-3.2 as well.
But remember you must place them in their own folders inside the plug-ins folder for them to work correctly or they will not show in the layers menu, Thanks again. :bigthup
PostPosted: Sat Feb 07, 2026 4:45 pm  (#3)
Haha, you caught me! Yes, I posted this here because I developed and tested it specifically for the GIMP 3.0 series.
It’s great to have your confirmation that it works smoothly in GIMP 3.2 as well—that’s very reassuring!
And thank you for the reminder about the folder structure. It's such a specific rule for GIMP 3.x that even I sometimes forget to mention it. I'll make sure to update the installation notes so others don't get stuck.
I also replaced the ZIP file with one that includes README.md.
Cheers! — Yousei3
PostPosted: Sun Feb 08, 2026 12:34 am  (#4)
Tested for Win10 and Gimp 3.0.4/3.0.8-1/3.2 RC2.
Please don't take my comment as criticism, but merely a suggestion. :hehe
Ungroup layers and group selected layers are not Photoshop-specific features.
The corresponding plugins have been available since at least GIMP 2.10 (including GIMP 3).
About Merging Selected Layers [Multi_Merge]:
Merges selected layers into a single new layer, preserving the original (non-destructive style).
1. This doesn't work for me – it merges the selected layers but doesn't preserve the original layers (it deletes them). Once you fix this, the name of this function should probably be New Layer from Selected (by analogy with New Layer from Visible).
Two layers selected:
Result of the action:
2. Changing the location of the 3 filter triggers (or adding a second location) from Layer to Layers, i.e.:
procedure.add_menu_path('<Layers>/Layers Menu')
PostPosted: Sun Feb 08, 2026 1:33 am  (#5)
Hi MareroQ,
Thank you for the clarification!
You're right—my README description was misleading.
My actual intention for "Merge Selected Layers" was the "destructive" style (merging and removing the originals), similar to how Photoshop behaves.
I believe users can simply duplicate layers beforehand if they wish to keep the originals.
I will correct the description in the README to avoid further confusion.
Also, thank you for the code tip! I'll definitely add procedure.add_menu_path('<Layers>/Layers Menu') to the scripts.
It makes sense to have these tools accessible directly from the Layers dock.
I'll update the scripts and the documentation soon. Thanks for helping me make this better! — Yousei3
PostPosted: Sun Feb 08, 2026 4:27 am  (#6)
Hi MareroQ,
Thank you again for your valuable feedback!
I’ve updated the ZIP file in the first post with the following improvements:
Right-click Menu Support: Added the tools to the `<Layers>/Layers Menu` as you suggested. It's much more convenient now!
Clarified "Merge" Behavior: Updated the README to clearly state that "Merge Selected Layers" is a destructive operation (similar to the Photoshop workflow) to avoid confusion.
Windows Support: Added Windows installation paths to the README so more users can enjoy the tools.
I really appreciate your help in making this project better.
Cheers!
— Yousei3
PostPosted: Mon Feb 09, 2026 2:35 am  (#7)
I was waiting an update of these (group linked layers & ungroup in 2.10) from ofnuts.
These work great, thank you Yousei3D.
PostPosted: Mon Feb 09, 2026 4:18 am  (#8)
It is reinventing the wheel to a certain extent.
There are some tools here: https://script-fu.github.io/funky/hub/plug-ins/folder/ together with MareroQ ungroup plugin.
PostPosted: Mon Feb 09, 2026 6:23 am  (#9)
Ohhh, I see. Funky stuff, I had already 2 wheels installed, what do I do with 3rd?
Build myself a Reliant Regal Gimp.
PostPosted: Sun Feb 15, 2026 1:14 pm  (#10)
Thanks for sharing.
