It is currently Sat Nov 07, 2026 3:11 pm
 Post subject: Path Shape Creator 2025
PostPosted: Sun Feb 08, 2026 7:02 am  (#1)
Author: Paco Garcia [arakne]
Source code: https://www.arakne.es/en/gimp-plugin-sh ... ator-2025/
In menu: Filters ➤ Path ➤ Shapes creator
This has already been written about here (thanks to Zbyma72age):
https://discuss.pixls.us/t/a-feature-yo ... -add/55812
and here (thanks to rich2005):
https://www.gimp-forum.net/Thread-arakne-path-shapes
However, for those who missed this great plugin for Gimp-2.10, it already has a Gimp 3 implementation and want a version that fixes two minor bugs:
1. The "Fill and border" ➤ "Fill:" ➤ "With pattern" option didn't work.
2. The translations don't work (the original was a mistaken reference to another plugin, "arakne-guides-lab").
Translations from arakne-path-shape-creator.mo (Gimp-2.10) work quite well after renaming it to path-shape-creator-2025.mo and placing it in the 'locale' subdirectory.
Translation 'pl':
path-shape-creator-2025.zip [77.55 KiB]
Downloaded 297 times
 Post subject: Re: Path Shape Creator 2025/2026
PostPosted: Thu Jun 25, 2026 7:30 am  (#2)
I'm very happy that this plugin is under constant development.
Many new shapes have been added in the following versions:
path-shape-creator-2026_05_28
https://www.arakne.es/plugin-gimp-shape-creator-2026/
To translations into 'de' and 'es' added 'pl'.
Fixed pattern fill.
path-shape-creator-2026.zip [112.38 KiB]
Downloaded 180 times
PostPosted: Thu Jun 25, 2026 10:59 pm  (#3)
Thanks for the update info MareroQ! Works great. :bigthup
PostPosted: Fri Jun 26, 2026 1:43 am  (#4)
Not sure where I got the link for this one from but have only tried one shape so far. Not even looked at it properly yet.
The gear - works well in vs 3x.
