It is currently Sat Nov 07, 2026 3:45 pm
 Post subject: pl_hexgrid for GIMP 3 has been updated to v0.16
PostPosted: Fri Jun 05, 2026 9:50 am  (#1)
The new version of my python plugin for drawing hexagonal grids has been released.
The plugin should now be more useful for general use: the hexagons centers alignment with the pixel grid can be bypassed if pixel-perfect rasterization is not needed. Vertical/horizontal lines are still always perfectly aligned to pixels, to avoid annoying blurriness.
As in previous versions, it offers the option to create nicely formatted sample sheet, if you need to choose visually the ideal size, along with the output of useful parameters. A new output is the number of contiguous hexagons and lines the current image can contain.
Anecdotally, for the mathematically inclined, these parameters output, and the filtering ability, can be used to search for the optimal discrete fractions which approximate square root of 3! ;-)
Download by clicking on https://github.com/Scallact/gimp-plugin-hexgrid, and the link under "Releases". Download the Source code at the bottom, and install it according to the description at the bottom of the Readme.
I invite you to read the documentation, as there are a few non trivial concepts and parameters.
 Post subject: Re: pl_hexgrid for GIMP 3 has been updated to v0.16
PostPosted: Fri Jun 05, 2026 12:39 pm  (#2)
Thank you :bigthup
PostPosted: Fri Jun 05, 2026 1:09 pm  (#3)
quietreader wrote:
Thank you :bigthup
It was about time I properly integrated your translation. I had to add some text, and tweak things a bit. Please, if you try it, tell me if you find anything clumsy. I did what I could with my limited knowledge of German.
Thanks again for your contribution! :bigthup
PostPosted: Sat Jun 06, 2026 4:51 am  (#4)
Your translation looks ok.
You could also add a translation for the layer name of the sample sheet.
Samples sheet = Musterblatt
For further updates you may well contact me via PM to help with translations.
PostPosted: Sat Jun 06, 2026 6:11 am  (#5)
Oh yes, you're right, I forgot this one!
Thanks for your offer, I'll keep that in mind.
