It is currently Sat Nov 07, 2026 3:11 pm
 Post subject: [Solved] Resize layer does not resize its picture
PostPosted: Sat Jun 06, 2026 2:08 pm  (#1)
Hello,
I am new to GIMP-scripting, but advanced in multiple programming languages. I managed to create a V3 script-fu function creating an image with several text layers, a few layers to draw on and a layer containing the picture. All layers can be scaled an placed individually as needed, but:
the picture in my layer does not scale/resize. The layer contour is resized however.
My relevant code lines:
(set! theFoto (gimp-file-load-layer 0 theImage theFile))
(gimp-image-insert-layer theImage theFoto 0 0)
(gimp-layer-resize theFoto 3000 1600 0 0)
What is it that I am missing here?
 Post subject: Re: Resize layer does not resize its picture
PostPosted: Sat Jun 06, 2026 8:09 pm  (#2)
Perhaps try,
(gimp-image-resize)
PostPosted: Sun Jun 07, 2026 12:06 am  (#3)
WP_Jules wrote:
Hello,
Resize and scale are two different things.
Resize changes the layer's size (with, height, offsets) as you have already seen, it doesn't scale the layer's contents.
If you want to scale use for example gimp-layer-scale.
PostPosted: Sun Jun 07, 2026 2:50 am  (#4)
@teapot: Thnkx ! Thatś what I needed.
@rod: I only needed 1 layer to scale, not the whole image.
