Supporting multiple languages should not require any changes to the program's functionality for individual languages. This idea stayed with me for a long time, so I considered how it could be implemented in a simple way. This is my proposal, and I have successfully applied the concept to two of my GIMP2 plugins:
"HN-Pfeil-zeichnen" (HN-Draw-Arrow) and "HN-Form-zeichnen" (HN-Draw-Shape).
If you are interested in the concept, please read the attached PDF file.
File comment: A Concept for GIMP Plugins and Other Python Applications.
Language Independent Python-GIMP-Plugins.pdf [247.87 KiB]
Downloaded 25 times
If you would like to test the described concept, use the ZIP file:
File comment: For your own tests.
Py3SprachunabhängigePlugins.zip [35.02 KiB]
Downloaded 18 times
The concept described was used in the following projects:
https://gimpchat.com/viewtopic.php?f=9&t=19081 -
https://gimpchat.com/viewtopic.php?f=9&t=17084 -
https://gimpchat.com/viewtopic.php?f=33&t=22936&p=305977#p305977
