It is currently Wed Oct 14, 2026 12:51 pm
 Post subject: Rectangle Select Tool Not Working
PostPosted: Sat Jul 19, 2014 4:46 am  (#1)
I'm having an issue with my rectangle select tool. When I pull it across, down, whatever.. there is no indicator of where you are. I restarted gimp and my computer, thinking that might help, but it hasn't. Any Advice? :tyspin
 Post subject: Re: Rectangle Select Tool Not Working
PostPosted: Sat Jul 19, 2014 4:51 am  (#2)
Is there the same problem for the ellipse tool?
PostPosted: Sat Jul 19, 2014 4:56 am  (#3)
no, just the rectangle
PostPosted: Sat Jul 19, 2014 4:59 am  (#4)
That is what is happening to me too. I pull the tool over where I want to go and it doesn't show anything but it does make the rectangle but I have no way of knowing how big it is until I let go of the tool.
PostPosted: Sat Jul 19, 2014 5:03 am  (#5)
exactly!
PostPosted: Sat Jul 19, 2014 6:42 am  (#6)
@Leigh, I figured it out. Uncheck the rounded corners box. and you will then see your selection.
PostPosted: Sat Jul 19, 2014 6:50 am  (#7)
That was my solution as well Molly. Maybe it's a bug?
PostPosted: Sat Jul 19, 2014 7:11 am  (#8)
Yeah, but in all the years using Gimp, this just started for me. Maybe it is a 2.8.10 bug, dunno but I am sure we aren't the only ones. (See Graechan... I am not the only one,) :teeth
Maybe some members would like to try clicking the rounded corners feature to see if they get the same result.
PostPosted: Sat Jul 19, 2014 7:58 am  (#9)
Thank you so much! I had this ticked before and it didnt do that... shrugs.. anyway, its fixed.. thank you!
