It is currently Mon Oct 12, 2026 7:42 am
 Post subject: What about GEGL?
PostPosted: Wed Sep 17, 2014 6:39 pm  (#1)
Well, from what I've read GIMP 2.10 will not be released until all native filters are ported to GEGL. From what I've seen in GIMP 2.9, remains a long way to reach that goal.
http://wiki.gimp.org/wiki/Hacking:Porti ... rs_to_GEGL
http://wiki.gimp.org/wiki/Hacking:Porti ... GL_and_GIO
http://gegl.org/index.html
I know nothing about programming. I know that in this forum there are very good scripts and plug-ins developers. I would like to know if you can explain me in simple words what you think/know about GEGL. What advantages does GEGL? How easy is to program filters in GEGL compared with current methods? Could GEGL make easier the creation of new filters to those who have no idea of programming?
:keybdtype
 Post subject: Re: What about GEGL?
PostPosted: Wed Sep 17, 2014 7:16 pm  (#2)
See http://en.wikipedia.org/wiki/GEGL
One advantage of GEGL is that it eventually lets Gimp describe internally the processing as a sequence of operations, so you can do non-destructive editing. A canonical example of the benefits is that when you apply several effects on text, you can still edit the original text and the effects will all be applied on the fly on the new text.
I haven't got the answer to the other questions, but programming is... programming. What is difficult is acquiring the mindset, the technique (Scheme, Python or some hypothetical GEGL node editor) is anecdotal.
PostPosted: Wed Sep 17, 2014 8:03 pm  (#3)
At GEGL site under Documentation have a look through the Operations. Many of the opening explanations are useful.
Here's a few more links,
Gimp Help 8.5. Use GEGL and 6.7. GEGL Operation
Gimp developer faq GEGL 4.3
GEGL explained
Making GEGL useful for applications beyond GIMP
PostPosted: Wed Sep 17, 2014 11:03 pm  (#4)
GEGL will allow (finally) a 16-bit/32-bit floating point color depth in GIMP.
For me, personally, this alone is a big deal of improvement. Among other things that high color depth brings is
a possibility for OpenEXR and HDR (radiance) support. Prokoudine mentioned multilayer OpenEXR exporter/importer
in his latest review here as a priority. These file formats make sense only at high color depth and I need them
for my 3D projects.
Other things that I find important if not imperative are:
RAW files from digital cameras without losing data (with appropriate RAW plugin ported to GEGL)
Graphics acceleration software to speed up rendering in GIMP (the developers are working on porting OpenGL to GEGL)
Gimp brush engine could do much better with GEGL too.
PostPosted: Thu Sep 18, 2014 12:15 am  (#5)
I don't think GEGL operations will be available to script writers unless something I don't know about happens
PostPosted: Thu Sep 18, 2014 6:40 am  (#6)
Thank you all for the explanations and links.
I understand some things. I do not understand much other related to technical programming terminology.
That about "operations" and "nodes" I do not know if I understand correctly. That means we could eventually have a graphical interface for creating filters based on nodes?
Also "operations" sounds me like procedures that can be stored neatly and then be repeated. It could GEGL facilitating add natively the feature of recording actions to be repeated later in batch? I read that record actions is a very requested feature by PhotoShop users.
PostPosted: Tue Oct 07, 2014 4:55 pm  (#7)
Just a few minor corrections, if you don't mind.
1) Filters don't absolutely have to be become GEGL operations all at once, but it would be nice.
2) OpenEXR and RGBE support is not a possibility, it's a reality by now, albeit in an unreleased state. Also, the OpenEXR plugin is very simplistic and doesn't yet provide any user-configurable settings for opening/exporting.
3) It's OpenCL rather than OpenGL, but the outcome is the same: GPU-side rendering and processing. Multithreading was experimentally added this summer as well.
4) There is no final UI decision made on how non-destructive editing would be implemented, exactly. GIMP might provide direct access to editing the graph or it might not. This is simply undecided, as there are more pressing matters currently.
5) Automating GIMP will eventually become simpler thanks to GEGL indeed, although, with a tree of nodes, there doesn't necessarily have to be a record button ;)
PostPosted: Wed Oct 08, 2014 4:06 am  (#8)
Appreciate the update. Indeed, there is no need for actions if you have nodes. :)
