It is currently Sun Oct 11, 2026 9:46 pm
 Post subject: GIMP-2.8.14 theme (Dynamic - Metallic Blue Licorice)
PostPosted: Sat Nov 15, 2014 2:30 pm  (#1)
viewtopic.php?f=12&t=4784
Grey block not "Crey" block. :lol
 Post subject: Re: GIMP-2.8.14 theme (Dynamic - Metallic Blue Licorice)
PostPosted: Sun Nov 16, 2014 8:10 am  (#2)
I think its related to Bug 736092 - "Some text strings in the UI have a strange background color problem (filled with whitish color)" and is related to the cairo bugs. As a workaround try to use the cairo version from gimp-2.8.10.
Unfortunately the bug in cairo is very hard to find and a volunteer (Jehan) who wanted to find and fix it has a virtual environment where this error does not occur, so he cannot find the bug.
Hatti
PostPosted: Sun Nov 16, 2014 8:24 am  (#3)
Thanks Hatti. Should i just use the cairo dll files from GIMP-2.8.10 then?
PostPosted: Sun Nov 16, 2014 11:14 am  (#4)
Yes. It is just one file: libcairo-2.dll
PostPosted: Sun Nov 16, 2014 6:04 pm  (#5)
Onkel Hatti libcairo-2.dll is in the bin and 32/bin folders for the 64bit 2.8.14, do we swap the both out with the files from 2.8.10
PostPosted: Mon Nov 17, 2014 12:21 am  (#6)
Yes, they both can be exchanged. For the ui, the one in the /bin directory is important. The one in the /32/bin directory is just for the environment to run 32bit plug-ins.
Hatti
PostPosted: Mon Nov 17, 2014 12:43 am  (#7)
when I changed the file in the /bin directory my gimp would not start
PostPosted: Mon Nov 17, 2014 7:23 am  (#8)
Ok i won't try that then. :lol
PostPosted: Mon Nov 17, 2014 11:42 am  (#9)
Whats the error message?
PostPosted: Mon Nov 17, 2014 5:19 pm  (#10)
I don't understand the message
PostPosted: Mon Nov 17, 2014 5:46 pm  (#11)
now I understand the message libpng15-15.dll was in my plugins folder instead of my bin I have shifted and now everything OK, thanks Onkel Hatti,Rod the bug has gone
PostPosted: Mon Nov 17, 2014 6:54 pm  (#12)
:roll: :teeth
PostPosted: Mon Nov 17, 2014 7:35 pm  (#13)
Molly Do you also have the abnormality described by Rod in 2.8.14
PostPosted: Mon Nov 17, 2014 10:36 pm  (#14)
I will. Check in the morning Graechan.
PostPosted: Tue Nov 18, 2014 6:51 am  (#15)
Graechan as i do not have GIMP-2.8.10 installed any longer can you post a download link for the dll file (libcairo).
My libpng dll file was in the bin folder already. Thanks.
PostPosted: Tue Nov 18, 2014 8:16 am  (#16)
Is this any help..librairo-2dl
libcairo-2.zip [519.82 KiB]
Downloaded 118 times
PostPosted: Sat Nov 22, 2014 6:21 pm  (#17)
Molly is that the cairo dll file from GIMP-2.8.10 or GIMP-2.8.14? It also needs to be a 64 bit dll.
I need GIMP-2.8.10's 64 bit libcairo-2.dll file. Thanks. :)
EDIT: This dll file does not work for 64 bit. it may for 32 bit though. If you download and try it KEEP your original just in case.
PostPosted: Sat Nov 22, 2014 9:06 pm  (#18)
Hi Rod,
Attachment here of a 'libcairo-2.dll' for GIMP-2.8.10 64 bits.
Also if you want to experiment a 'libcairo-2.dll', that is more than 5 time the size of the former, for GIMP-2.8.15 64 bits from samj.
Regards.
' for GIMP-2-8-15 64 bits..zip [1.22 MiB]
Downloaded 130 times
' for GIMP-2.8.10 64 bits..zip [317.79 KiB]
Downloaded 121 times
PostPosted: Sun Nov 23, 2014 9:06 am  (#19)
rob_brz1 wrote:
Hi Rod,
Regards.
Thanks but i have gotten the correct one already. :) Thanks to Graechan. I haven't tested the 1mb libcairo-2.dll yet. Anyone tested this one compiled by Sam for GIMP-2.8.15?
PostPosted: Mon Nov 24, 2014 1:50 am  (#20)
Thanks for the info Rod; that worked. Molly's 32-bit version messed up PSPI for whatever reason so I replaced the 32-bit version with the one that installed for 2.14. All's well and now I have my biggy layer mode back again. lol
