It is currently Sun Oct 11, 2026 2:48 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Image steganography
PostPosted: Mon Apr 13, 2015 10:36 am  (#1)
Hello
I can't see my previous post that i posted under the subject image steganography. How can i get that posts & its replys.Please help me to get back my posts in image steganography....
 Post subject: Re: Image steganography
PostPosted: Mon Apr 13, 2015 11:10 pm  (#2)
While searching code for image steganography i will get a java code. Please help me to convert that code into gimp plugin that is written in python language.I think this code works properly.................. picture.java
PostPosted: Tue Apr 14, 2015 5:39 am  (#3)
@jismy:
You haven't posted a link above, but I believe the site you referred to in the previous thread (which seems to have disappeared) was this:
http://students.iitk.ac.in/projects/steganography
This seems to have been a project undertaken by students at the Indian Institute of Technology, Kanpur.
They ended-up using Python (not Java).
The project summary does not state what encoding technique they actually used, but there must be some sort of group-encoding used, perhaps BPCS (see http://en.wikipedia.org/wiki/BPCS-Steganography). They also used re-scaling to help squeeze the "hidden" image into the carrier image.
Implementing BPCS is not a trivial exercise - there would be a considerable amount of work involved.
(There is a BCPS steganography program for Windows available here: http://datahide.org/BPCSe/QtechHV-program-e.html)
Why do you need the code as Gimp plugin (rather than a standalone program, run under Windows or Linux)?
And why does it have to be written in Python?
(There is already a Gimp C plugin available to do LSB encoding here http://registry.gimp.org/node/25988) which does work (at least on small images, though I think there may be a problem with larger images).
PostPosted: Tue Apr 14, 2015 6:10 am  (#4)
The original topic was moved out of the public boards , due to some posting anomalies. This topic will be temporarily locked until these issues are resolved.
Thanks for your understanding in this matter.
