It is currently Sat Oct 10, 2026 5:34 pm
 Post subject: How to cut images with polygonal shapes?
PostPosted: Tue Apr 14, 2015 6:08 pm  (#1)
Hello everybody. I'm new in the forum. I want to post a question with a link as an example but I receive this stupid message again and again "Your post looks too spamy for a new user, please remove off-site URLs", and I don't know how to use either the web adress code. I want to learn. I need to figure out how to cut some images with polygonal shapes.
 Post subject: Re: How to cut images with polygonal shapes?
PostPosted: Tue Apr 14, 2015 6:16 pm  (#2)
You will not be allowed to include off-site links until you have made at least 5 posts.
In the meantime, you can upload files as attachments, so download an image from the link or take a screenshot of it and upload the image as an attachment.
PostPosted: Tue Apr 14, 2015 6:49 pm  (#3)
Welcome to Gimp Chat lucasgburgos. :)
PostPosted: Wed Apr 15, 2015 2:29 am  (#4)
All images are rectangular, those that look polygonal are still rectangular but have transparent margins and corners. So to make an image look polygonal.
- Make a polygon selection (Freehand selection in polygon mode, or using the path tool and Select>From path). If you need a regular polygon there are scripts to generate paths with such shapes.
- Add an alpha channel for transparency (Layer>Transparency>Add alpha channel)
- Select>Invert (Ctrl-I) and Edit>Clear ([delete])
- You can reduce the image to the strict minimum to encompass what is left with Image>Autocrop image
- Export in a format that supports transparency (PNG), unless you want the margins filled with a default background color.
