 Post subject: Why is linux a better choice than windows for gimp users?
PostPosted: Sun Jul 26, 2015 6:28 am  (#1)
sorry for posting it here but can anyone explain to me why linux is better choice than windows for gimp users?
 Post subject: Re: Why is linux a better choice than windows for gimp users?
PostPosted: Sun Jul 26, 2015 8:15 am  (#2)
IMHO, the better choice has more to do with a users knowledge of their own OS.
I'm curious why your asking this question?
PostPosted: Sun Jul 26, 2015 8:31 am  (#3)
Most likely because the default native platform libraries are Linux.
It just runs better and faster on Linux.
PostPosted: Sun Jul 26, 2015 8:48 am  (#4)
IMHO, Linux is better all around for everything.
PostPosted: Sun Jul 26, 2015 10:00 am  (#5)
Just my opinion, but I tend to agree with Rod, in that installation can be easier in Linux. GIMP is compiled for all of the popular Linux distribution's, against the latest libs for that distribution, so installation is a snap. With all the various versions of Windows available, it can sometimes be confusing or difficult to install. Conflicting DLLs, as well as python installation, can also present pitfalls when using Windows.
GTK+ is also a bit less quirky in Linux than Windows.
PostPosted: Sun Mar 04, 2018 10:07 am  (#6)
Linux might be a better choice if you are using the standard 2.8 version but i think windows is better if you are using 2.9 versions.
I have tried installing 2.9 on my linux system with no success, I then tried an app image for 2.95 and it wouldn't startup! I eventually found an app image for 2.99 and it works. Appimages are supposed to be selfcontained a bit like a portable programm on windows.
using Gimp 2.10.8 with Linux on an ancient laptop
PostPosted: Sun Mar 04, 2018 1:11 pm  (#7)
Gimp works equally well on both platforms. Linux has a slight edge if you write scripts or use a tablet.
Otherwise, Linux is a better platform, period, even if you don't use Gimp.
PostPosted: Sun Mar 04, 2018 1:41 pm  (#8)
what ofnuts said ^ ^
