It is currently Sat Oct 10, 2026 5:33 pm
 Post subject: Is gimp development version slower?
PostPosted: Mon Sep 07, 2015 9:05 pm  (#1)
I have installed gimp from git, development "2.9" version. I wanted to try higher bit precision support and other features. But when I scale down a large image, it takes centuries to complete. I even have OpenCL enabled (and the system is supposedly capable). Could we expect this is going to be resolved in the first official 2.9 point release?
 Post subject: Re: Is gimp development version slower?
PostPosted: Mon Sep 07, 2015 10:47 pm  (#2)
The short answer is yes.
PostPosted: Mon Sep 07, 2015 11:43 pm  (#3)
I heard they recently changed the algorithm for downsizing, but I wouldn't have expected it to be noticeably slower. Interesting. :)
PostPosted: Tue Sep 08, 2015 4:42 am  (#4)
This is a development version, not fit for "production". Use at your own risk.
Anything can happen, you can have trace code remaining and slowing things, or some optimization turned off.
You can start to worry about performance when this becomes a "Gimp 2.10 release candidate".
PostPosted: Wed Sep 09, 2015 2:39 am  (#5)
Thanks for the response. I am just stuck on gimp dev now because I've saved a lot of files in 16 bit mode, and 2.8 doesn't support them.
