It is currently Sun Oct 11, 2026 12:01 pm
 Post subject: GIMP-2.8 version crashes and ABR-64 bit brush loader
PostPosted: Fri Dec 18, 2015 6:12 pm  (#1)
I noticed something a little peculiar today. I decided to re-compile the ABR.c plug-in to load Photo Shop brush files in layers in GIMP. Well after i compiled the plug-in and added it to my plug-ins folder i restarted GIMP and GIMP loaded and looked fine until i tried to open any file. Then it crashed. No error just crashed. So i removed all the rc files and restarted. GIMP crashed again. So i re installed GIMP and GIMP still crashed. So i decided to go systematically by removing plug-ins first. Still a crash. The only thing left were brushes, patterns, and scripts in my user folders so i removed the patterns except the ones i need to run my own scripts. GIMP ran fine. I reloaded all my other rc files and what not back into GIMP and everything ran fine. I re loaded all the pattern files and GIMP crashed.
So thinking well this all started with ABR.exe i reloaded it back into the plug-ins folder. GIMP ran and loaded the abr file perfectly. SO my conclusion is that not all pattern files work with GIMP :lol
AND my newly compiled version of ABR loader does work so i attached it here. :)
ab_64Bit_Windows-10_RDr.zip [15.04 KiB]
Downloaded 171 times
By the way i am using this executable in GIMP-2.8.16 64 bit.
 Post subject: Re: GIMP-2.8 version crashes and ABR-64 bit brush loader
PostPosted: Fri Dec 18, 2015 6:32 pm  (#2)
I thought .abr support was built in to GIMP 2.8x?
PostPosted: Fri Dec 18, 2015 6:44 pm  (#3)
It is but the built in adaptability only opens certain ones. This plug-in should open MOST Adobe ABR files.
I should also mention that you can load multiple layers from the abr file and save the ones you want as gbr files and toss the rest.
