It is currently Sun Oct 11, 2026 9:19 pm
 Post subject: Flip Inside Out
PostPosted: Tue May 10, 2016 5:28 pm  (#1)
Hey,
This is my first post...I was wondering in GIMP 2 if there was a way to flip a selection inside out.
Eg
Given the image on the left and using the BLACK circle as circle-select, I want to be able to take what is "inside" the selection and mirror it to the "outside" and take what's "outside" and flip it to inside the selection circle.
Thanks in advance
 Post subject: Re: Flip Inside Out
PostPosted: Tue May 10, 2016 7:26 pm  (#2)
Welcome to the forum, RandimNaSeen.
I'm not able to help you, but there are many experts in the forum and I'm sure one of them will soon come by to say Hello and be able to help you.
PostPosted: Tue May 10, 2016 7:58 pm  (#3)
Used Mathmap>Distort>Radial Inversion to get this result. Still not quite what you wanted though. :)
PostPosted: Tue May 10, 2016 8:36 pm  (#4)
Thanks Pat625 it's nice to hear there are experts to help out.
lylejk - I downloaded Mathmap and imported the plugin but I can't find "...>Distort>Radial"
PostPosted: Tue May 10, 2016 8:40 pm  (#5)
Put this one (unzip first of course) into your mathmap's expression>distortion folder. :)
Radial Eversion.7z [269 Bytes]
Downloaded 198 times
PostPosted: Tue May 10, 2016 9:03 pm  (#6)
Thanks for your patience
I'm finding my MathMap under "Filters>Generic>MathMap>MathMap" and when I try to use "Radial Eversion" I get the error "`llvm_template.o' needs to be located in one of the following folders..." Maybe I'm too tired but I feel like an idiot. Does it matter if I'm using 2.8 and the plugin is 2.6?
PostPosted: Tue May 10, 2016 9:09 pm  (#7)
I've found a rewording for my question. Essentially all I want is a "Mirror" I can shape, say a circle from the above answer. Or be able to shape a mirror with the free-tool-selection. I don't think MathMap is the way to go, I appreciate the idea, but I'm just going to end up wasting your time playing with the MathMap plugin.
Thanks for understanding
PostPosted: Tue May 10, 2016 9:52 pm  (#8)
if you look carefully at the math map result it pretty much gives you what you want...i don't have mathmap either but just observing the result look at the highlighted portion
PostPosted: Tue May 10, 2016 10:19 pm  (#9)
Good eye, Tran. :)
PostPosted: Wed May 11, 2016 10:48 am  (#10)
Thanks again Lyle, I was able to finally get MathMap to work, I must've been really tired (or stupid) last night. I'm trying to use it for odd shapes so I'm going to continue to play with it. I'm trying to use it for UV Mapping in Blender.
Thanks everyone
cron
