It is currently Sun Oct 11, 2026 6:37 pm
 Post subject: windows very big
PostPosted: Thu Aug 04, 2016 1:25 pm  (#1)
some windows like scrip fu tex logo buttons up part is not seen under such ok and cancel etc is very large window what can i do :gaah
 Post subject: Re: windows very big
PostPosted: Thu Aug 04, 2016 1:45 pm  (#2)
yes, you need the scrolling version available for parameters list
Wallace will be more precise on that
http://gimpscripts.com/2014/06/script-f ... interface/
PostPosted: Thu Aug 04, 2016 2:05 pm  (#3)
I use a large resolution and had the same problem, however you can drag the Script-Fu box around by left click and hold on your mouse, I also put my windows tool bar to the left of my screen, in Peace RJKD
