It is currently Sun Aug 16, 2026 7:00 am
 Post subject: How to not colour black.
PostPosted: Sat Sep 10, 2016 5:41 am  (#1)
So I want to color something in another layer but it goes through the black lines and I want it to not color anything that is black.
 Post subject: Re: How to not colour black.
PostPosted: Sat Sep 10, 2016 6:32 am  (#2)
What do you mean by "it goes through the black lines" Can you show an example image please?
PostPosted: Sat Sep 10, 2016 6:50 am  (#3)
I want to select everything that is black and not go through it.
PostPosted: Sat Sep 10, 2016 6:55 am  (#4)
Try "Select by color tool" click on any color black in the layer. Now select "Select Invert" now paint.
PostPosted: Sat Sep 10, 2016 6:12 pm  (#5)
Draw the line art in a transparent layer then color underneath on another layer.
PostPosted: Sat Sep 10, 2016 6:13 pm  (#6)
Just move the layer with the red lines under the layer with the black ones. This can also be done before you paint since painting goes to the active layer, and not mandatorily to the top one, so it is possible to paint "under" something by selecting a layer under before painting.
RedAndBlack.xcf [26.16 KiB]
Downloaded 213 times
PostPosted: Sun Sep 11, 2016 1:55 am  (#7)
It was my understanding the black lines and paint are on the same layer.
PostPosted: Sun Sep 11, 2016 6:03 am  (#8)
The crux of Gimp is to use separate layers whenever appropriate.
