It is currently Fri Aug 14, 2026 9:57 pm
 Post subject: Trying to install GIMP on laptop
PostPosted: Thu Dec 08, 2016 2:42 pm  (#1)
Hi there,
I copied the gimp-2.8.18-setup.exe file on my desktop (where it's working fine) on to a working flash drive and then copied to my laptop.
I then installed GIMP on the desktop.
One - it does not display in Start > All Programs but does display under CCleaner.
Two - when I right-click on that gimp-2.8.18-setup.exe file and choose Send to Desktop it creates a shortcut on the desktop but when I click on that shortcut it prompts me to sign in under Admin and not regular user Under Windows 7.
Q 1: is this a trusted site to download GIMP? - https://www.gimp.org/downloads/
I could not find any FileHippo or Pririform page which listed GIMP (they both have been trusted sites).
Q 2: why doesn't GIMP show under Programs in W7?
Q: 3 how can I run GIMP in regular user and not Admin in W7?
Thanks so much.
 Post subject: Re: Trying to install GIMP on laptop
PostPosted: Thu Dec 08, 2016 2:58 pm  (#2)
eagertolearn wrote:
Hi there,
That is the place to get it.
A quick way of getting ad-ware installed
I did this installation advice video for Win10 - only 3 minutes duration
https://www.youtube.com/watch?v=klV_1PslFG4
Win 7 is exactly the same, have a look see if you can find where you are going wrong.
PostPosted: Thu Dec 08, 2016 3:51 pm  (#3)
Rich 2005 - Thank you. I'll download accordingly.
Good point about clicking the Help tab and creating one window.
Where do I get the GIMP Help files?
How then to I install them?
Thanks again.
PostPosted: Fri Dec 09, 2016 3:54 am  (#4)
That was part of three, short, 4 minute videos, I did for another forum
Installing help should be straight forward if you are using US English.
https://download.gimp.org/mirror/pub/gi ... -setup.exe download and run.
otherwise just look in https://www.gimp.org/downloads/ for the list languages.
Other languages can sometimes be a problem example:
UK English (aka English ;) )
https://www.youtube.com/watch?v=SWCujrZWuSs
and a bit about installing resources:
https://www.youtube.com/watch?v=q0HyFsGrNAc
PostPosted: Sat Dec 10, 2016 9:48 am  (#5)
What I have done with gimp is after finding the program and opening it I pinned it to my task-bar so I always have the shortcut there.
Yes I use a laptop too.
