It is currently Mon Nov 23, 2026 12:02 pm
 Post subject: Text
PostPosted: Fri Feb 17, 2017 6:12 pm  (#1)
Yes I am trying to align text in the middle of a picture. I'm so confused I use the alignment tool but it only moves the text very little. I will click the align middle of target and it moves down very little. I can see it move but it does not move to the middle of the picture at all. I don't know what's wrong. Does anyone have any thoughts?
 Post subject: Re: Text
PostPosted: Fri Feb 17, 2017 6:23 pm  (#2)
Auto-crop the text layer,
then try using the Alignment Tool again.
PostPosted: Fri Feb 17, 2017 6:46 pm  (#3)
Thank you so much. That worked. I'm new to Gimp, thank you again.
PostPosted: Fri Feb 17, 2017 8:31 pm  (#4)
The align tool works using the layer borders and doesn't consider the layer contents.
PostPosted: Sat Feb 18, 2017 4:56 am  (#5)
Great you got your answer. Thanks for asking. I was confused by that tool too. What I normally do is have the text layer the size of the picture and use left, centre, right justify and then move it to where I need it.
