 Post subject: How to resize without blurriness?
PostPosted: Tue Sep 26, 2017 5:09 am  (#1)
Hello,
I am trying to resize a existing image. The original size is 900 * 858 px (It can be anything) and I want to make this image to size 16 * 15 px (Again, it can be anything).
Now I have tried every possible solutions scale/change print size/Fit Layer to Canvas/Fit Canvas to Img ...etc etc. But I just can seem to resize the image without bluriness.
My image is a transparent png, I tried with a non-transparent(basic) image but either ways the result is blurry.
Can someone tell me a foolproof way to do it?
Thanks
 Post subject: Re: How to resize without blurriness?
PostPosted: Tue Sep 26, 2017 5:19 am  (#2)
Ofnuts will help you with this one. As odd as it sounds I seem to recall you have to apply blur before reducing but I can't remember the ratio. It's all to do with mathematics! :?
PostPosted: Tue Sep 26, 2017 5:35 am  (#3)
Ofnuts can often perform miracles but in this case, perhaps not ;)
All depends an the image, but 900 pix -> 16 pix is a big jump.
For CGI type graphics sometimes setting interpolation to none works
but not for regular graphics.
Scaling down say 50% then a small pre-blur: File -> Gaussian blur with value 2 then Scale Image using either lancos or bilinear.
Scaling down to less than 25%, IMHO never going to be wonderful, again depends on original image.
PostPosted: Tue Sep 26, 2017 5:38 am  (#4)
Thanks rich, I just found his post in case it is of any help in understanding similar problems.
viewtopic.php?f=8&t=4124&p=52865&hilit=mathematically#p52865
PostPosted: Tue Sep 26, 2017 6:54 am  (#5)
"I find your lack of faith disturbing"
(c) Vader & Death Star Associates, inc
PostPosted: Tue Sep 26, 2017 7:44 am  (#6)
:hehe :hehe :hehe :hehe :hehe :hehe
PostPosted: Tue Sep 26, 2017 9:11 am  (#7)
Oh, No! I sense a rumble in the force!
PostPosted: Tue Sep 26, 2017 9:53 am  (#8)
I have read the OfNut process - Thanks Erisian and rich2005 process. Will try both individually and see if I can get a resultant o/p.
Also I was considering being able to change by png img to a svg, since the o/p is for the web? Any thoughts if that can help.
Thanks
PostPosted: Tue Sep 26, 2017 10:06 am  (#9)
Rich - I am settling with your "IMHO" as close to facts :)
Ofcourse post trying out the solution provided by you.
PostPosted: Tue Sep 26, 2017 12:27 pm  (#10)
It can, if you do it from scratch and keep it very simple.
