It is currently Mon Nov 23, 2026 12:00 pm
 Post subject: Hidden Tools in Gimp 2.10
PostPosted: Thu Jul 12, 2018 8:48 am  (#1)
This may not be new to you people, but I just found out about it yesterday. These tools are in the Play Ground. In order to activate these tools, you need to add this switch in your Gimp ShortCut: --show-playground , then go to Edit > Preferences and enable them under PlayGround.
I like N-Point Deformation. Here's how it works: https://www.youtube.com/watch?v=OmOyQyuiO_E
Here is a chain I distorted from straight (on left) to curved (on right).
 Post subject: Re: Hidden Tools in Gimp 2.10
PostPosted: Thu Jul 12, 2018 11:35 am  (#2)
racer-x
Thanks. Please keep posting such tips.
-Eureka
PostPosted: Thu Jul 12, 2018 12:21 pm  (#3)
Yeah; got this to work when I was using samj's portable a few months ago. When I finally decided to do the full install, got it to work again. Still; very taxing to my 2014 built PC; probably need to get an upgrade. lol
PostPosted: Thu Jul 12, 2018 4:58 pm  (#4)
PostPosted: Thu Jul 12, 2018 6:48 pm  (#5)
Here's how it looks in the shortcut to Gimp 2.10.4 AppImage in Linux: path/to/gimp2.10.4.AppImage --show-playground
Put the switch at the end of the command and make sure it has a space before it. I don't have Windows, but it should be similar.
PostPosted: Thu Jul 12, 2018 7:58 pm  (#6)
If you are using samj's portable version, see link below to enable extended features. :)
viewtopic.php?f=7&t=16456&p=227395#p227393
PostPosted: Fri Jul 13, 2018 1:21 pm  (#7)
lylejk & racer-x,
Thank You both for the helpful hints on how to gain
access to "the playground",
Will attempt both hints in the near future.
Mainah_Ayuh :musik :thanku
