It is currently Mon Oct 12, 2026 2:30 am
 Post subject: Multi picture/page layout
PostPosted: Mon Aug 27, 2018 12:32 pm  (#1)
I am comparing multiple versions of the same design I am doing and am of the opinion that it would be rather convenient to have a gimp layout with multiple images/pages laid out in the window.
Is this a possibility?
 Post subject: Re: Multi picture/page layout
PostPosted: Mon Aug 27, 2018 1:28 pm  (#2)
Maybe a temporary use of g'mic montage.
This a stack of 4 variations.
This the g'mic montage filter - custom mode - all layers - new image edit: Well maybe the auto works, don't know how I got that screenshot ;)
Gives this:
Some g'mic custom variations
2x2 V(H(0,1),H(2,3))
2X3 V(V(H(0,1),H(2,3))),H(4,5))
3 wide x 2 deep H(H((V(0,1),V(2,3))),V(4,5))
PostPosted: Mon Aug 27, 2018 1:51 pm  (#3)
Yes, just uncheck Windows>Single window mode.
PostPosted: Tue Aug 28, 2018 2:39 am  (#4)
Well, unchecking the single window mode just separates everything. I was imagining a couple images -- each still editable -- simultaneously in the main window instead of having to shift between images/windows.
Oh well.
Thanks anyway.
PostPosted: Tue Aug 28, 2018 5:05 am  (#5)
Oh well.
Thanks anyway.
You would end up with two windows anyway... Sooner or later you'll want the name of the image (so, a titlebar...), the scales, the status area (zoom level, pointer position), the quickmask button, maybe a different view filter, and a way to tell Gimp which one you are looking at (to show layers in the Layers list, for instance). So we would be talking about windows within windows... which was a fashionable UI feature until the mid-90s.
