 Post subject: Gimp manual
PostPosted: Wed Dec 26, 2018 7:52 am  (#1)
Is it possible to use in gimp portable 2.10.8 of samj this help file proposed for gimp 2.8.1 here:
http://www.aljacom.com/%7Egimp/documentations.html
 Post subject: Re: Gimp manual
PostPosted: Wed Dec 26, 2018 10:49 am  (#2)
Yes, it works. Just follow the directions in the zip
Some files go in ..path-to../Gimp-2.10.6_Portable-32bit-64bits/bin/ https://i.imgur.com/7q7RmEM.jpg
The help folder goes in ..path-to../Gimp-2.10.6_Portable-32bit-64bits/share/gimp/2.0/ https://i.imgur.com/t0bGvt6.jpg
Make sure the prefernces are set up. Do not use the Gimp browser, it does not work with Gimp 2.10 use the web browser option (can be an issue if using, say, firefox) https://i.imgur.com/DxpG8WH.jpg
F1 and looks like this. Ancient ;) https://i.imgur.com/PS47Mcq.jpg
PostPosted: Wed Dec 26, 2018 1:11 pm  (#3)
rich2005
thank you for your explanations with screenshots :)
it works :bigthup
The folder "help" contains 2 folders:"en" ( 425 KB) and "fr" ( 431 KB)
They each contain 1010 bat files
So can I delete the "in" folder?
PostPosted: Wed Dec 26, 2018 1:28 pm  (#4)
..So can I delete the "in" (en) folder?..
Short answer - yes
Longer answer - when in doubt about deleting anything, move it out somewhere safe as a backup or rename to disable. When certain no longer needed, then delete.
Edit: the file gimp_en.chm is 26MB, you do not need that either for French help.
PostPosted: Wed Dec 26, 2018 1:53 pm  (#5)
very wise answer! :) ;)
I did not see that one in the folder "bin" ..
26.6 MB is not very much but already Gimp is very very long to open
