 Post subject: Reset GIMP?
PostPosted: Mon Feb 24, 2020 2:26 pm  (#1)
Hey,
I'm an occasional GIMP user, or rather I have used it alot in the past but it's been a while. I downloaded a new (for me) version GIMP 2.10 recently, but it seems like I have managed to change the settings some how and now i can't do anything.. When i click entire areas just blink purple. Is there a way to completely reset all settings?
Grateful for any help!
 Post subject: Re: Reset GIMP?
PostPosted: Mon Feb 24, 2020 2:46 pm  (#2)
Welieu wrote:
Hey,
You can reset gimp to it's default values within Preferences.
Go to: Edit > Preferences.
If this doesn't help.
You my need to have Gimp create a new user profile.
PostPosted: Mon Feb 24, 2020 3:53 pm  (#3)
I didn't work :( How do I create a new users profile?
PostPosted: Mon Feb 24, 2020 5:19 pm  (#4)
Hi Welieu.
https://www.gimp.org/tutorials/GIMPProfile/
PostPosted: Mon Feb 24, 2020 7:43 pm  (#5)
Rename your current profile to something like .gimp-2.10.old. and restart GIMP.
GIMP will recreate a new profile once launched,
which may fix the issue.
PostPosted: Mon Jun 29, 2020 3:51 am  (#6)
I guess that trick blew up his computer. ;)
