It is currently Fri Oct 09, 2026 8:48 am
 Post subject: Text Wrapping Wrong
PostPosted: Mon Sep 07, 2020 12:04 am  (#1)
I am a beginner at this time. Using v. 2.10 on Linux Mint 19.1 with i5 cpu.
I tried this tutorial from YT:
"GIMP Tutorial: Wrap Text Around A Circle"
(I have no connection with this website or content other than as a learner.)
But my text wraps in the wrong way so that the lower line would be upside down to the reader.
The text should wrap as in the first screenshot:
My text:
I have tried using the flip tool without success so far.
Any suggestions on what I am doing wrong and how to correct this would be appreciated.
 Post subject: Re: Text Wrapping Wrong
PostPosted: Mon Sep 07, 2020 12:44 am  (#2)
You need to reverse the stroke of the circle path. You can use Ofnut's "reverse strokes" plugin or flip the path horizontally using the Flip Transform tool.
https://sourceforge.net/projects/gimp-p ... p/download
Remember, you're flipping the circle path, not the text.
PostPosted: Mon Sep 07, 2020 1:44 am  (#3)
Thanks for responding. I will try flipping the path.
I have now 3 layers in the document.
If I go to paths, I see two paths:
1. "around a circle" (the text_
2. a path called selection. I assume this is the path I must work with.
I select this path, the circle turns red.
I open flip tool
under transform I choose path, and make sure horizontal is checked.
the circle jumped to the right and left off center. l used ctrl - z to undo that
but it does not seem to be doing anything
I am afraid I don't understand what is going on at this point.
PostPosted: Mon Sep 07, 2020 1:57 am  (#4)
If your circle path is centered in the exact middle of the drawing, when you flip the path (just one click on the circle path layer - double arrow should be <--->), it should just reverse the stroke direction. The path itself should not even change locations.
You could also try redrawing the circle selection and saving it to a path, to try again. That didn't work for me.
PostPosted: Mon Sep 07, 2020 5:22 am  (#5)
Gimp 2.10.20
A 45 second video/animation that might help. https://i.imgur.com/2ygIsA2.mp4 I put a little tick in the circle to show the flip (not to be used in real world) Remember one click is all that is needed with the flip tool.
PostPosted: Mon Sep 07, 2020 6:30 am  (#6)
[quote="mahvin"]If your circle path is centered in the exact middle of the drawing, when you flip the path (just one click on the circle path layer - double arrow should be <--->), it should just reverse the stroke direction. The path itself should not even change locations.
your advice worked perfectly.
Thanks a lot.
What I just found out reviewing this is, that if I activate the flip tool and go into the circle and click, the circle changes position. So I undo that action, the click exactly on the circle. Then the circle stays put. I can then go to "text along path" and it works.
a separate issue came up though. I had made the text to wrap a round a circle filled with background color, but
my finished jpeg shows the entire background color filling a square with the text inside. I must have made a mistake with the layers.
here's what I made in GIMP:
PostPosted: Mon Sep 07, 2020 9:57 am  (#7)
The only images that qualify for transparency are PNGs. JPG files will fill with a background color. Try exporting the file as a PNG and make sure "Keep background color" is unchecked.
PostPosted: Tue Sep 08, 2020 1:09 am  (#8)
you are a master. It worked
Thanks.
