It is currently Fri Aug 14, 2026 11:57 am
 Post subject: Gimp is not behaving in scaling images.
PostPosted: Sun Jan 24, 2021 11:23 am  (#1)
About 4 days ago, I tried to resize an image layer. The entire image (all layers) tried to resize at once.
I couldn't figure it out so I uninstalled Gimp and reinstalled it thinking I'd done something wonky with configurations I couldn't figure out.
Now, I have found out about floating layers, so that's resolved. However, now, when I try to resize a layer, telling it to get smaller, it gets bigger!
The scale numbers go down while I am pressing the down-arrow beside the parameters. But, when I release the button, the scale actually goes up and increases in size.
What am I doing wrong? I am not doing anything differently than I did 5 days ago, but the responses by Gimp are opposite what I want for scaling.
Gimp 2.10.22.
Thank you.
 Post subject: Re: Gimp is not behaving in scaling images.
PostPosted: Sun Jan 24, 2021 12:32 pm  (#2)
Not sure what you are talking about, but here is the correct way to scale a layer using the layer scaling tool.
