It is currently Mon Nov 23, 2026 2:07 pm
 Post subject: Get use to using GEGL Graph syntax.I can't make a filter of everything
PostPosted: Sun Jun 12, 2022 1:25 pm  (#1)
Not everything cool GEGL does can easily be made into a filter. We need to get into a habit of sharing GEGL syntax with each other to do cool things. today I will be sharing a 3d text styling effect. You must replace my home path with a path of your own. GEGL cannot link images from the internet (we tried)
transform transform=matrix(1.0156650757686598,0.075701741929592628,0.000365746118200971,0.013317261513591921,1.2296272065975005,9.0806881192612718e-05,0,0,1)  first-iteration=1 iterations=0 fade-opacity=1 paste-below=no sampler-type=nohalo
gegl:color-overlay value=#dbdbdb
(GRAYSCALE PATTERN OVERLAY)
svg:src-atop aux=[gegl:layer src=/home/contrast/Pictures/Magic/Gradient_overlays/green.png]
gaussian-blur
emboss  type=bumpmap azimuth=30 elevation=45 depth=12
gegl:dropshadow x=0.00  y=0 radius=0.00 grow-shape=circle grow-radius=1 opacity=2 color=#ffffff
gegl:dropshadow x=0.00  y=0 radius=0.00 grow-shape=circle grow-radius=6 opacity=1 color=#ffffff
gegl:dropshadow x=0.00  y=0.00 radius=0.00 grow-shape=circle grow-radius=6 opacity=1 color=#000000
gegl:dropshadow opacity=0.4 radius=0.1 x=-1.8 y=2.8
gegl:long-shadow style=finite angle=152.94 length=18 midpoint=100 midpoint-rel=0.5 color=#000000 composition=shadow-plus-image
Alternative Graph
recursive-transform time=0 transform=matrix(0.85676532983779907,-0.083190269768238068,-1.0763975295356106e-19,0.15398488938808441,1.0494217872619629,-2.1621131194246602e-19,35.636863708496094,106.15763092041016,1)  first-iteration=1 iterations=0 fade-opacity=1 paste-below=no sampler-type=nohalo
svg:src-atop aux=[gegl:layer src=IMAGE FILE OVERLAY HERE]
(bevel)
gaussian-blur
gegl:long-shadow style=finite angle=152.94 length=11 midpoint=100 midpoint-rel=0.5 color=#000000 composition=shadow-plus-image
Image used.
Have fun.
 Post subject: Re: Get use to using GEGL Graph syntax.I can't make a filter of everyt
PostPosted: Sun Jun 12, 2022 3:22 pm  (#2)
"I can't make a filter of everything"
Not so fast! You are doing a hell of a job so far!
:mrgreen:
PostPosted: Sun Jun 12, 2022 10:10 pm  (#3)
:mrgreen:
Hell yes! I cannot agree more.
@contrast_ You are doing an absolute great job, thank you so much :tyspin
Patrice
PostPosted: Sun Jun 12, 2022 10:32 pm  (#4)
Thank you all. But seriously this filter won't happen because GEGL cannot call Gimp's 3d transform unless Gimp is rebuilt from source.
PostPosted: Mon Jun 13, 2022 8:03 pm  (#5)
Did you tried with the other transform tool like the unified transform tool?
Or the Filters/Map/Recursive transform... (with "First iteration" set at 1 and "Iterations" set at 0), because it's a filter, maybe it can work?
Patrice
PostPosted: Mon Jun 13, 2022 9:47 pm  (#6)
No it will not work and I tried exactly that with recursive transform. I forked recursive transform and it had a dialog with numbers and the words "transform" with no on canvas abilities. I was wondering where the on canvas transform was. A gimp dev then explained that transform and gradients on canvas are controlled by Gimp (not GEGL). GEGL does the image processing while Gimp does on canvas tools. Only certain filters are white listed to use on canvas tools.
I'm upset because of that. This also prevented me from making a border filter by forking vignette. We can't work around this unless there is a way to patch Gimp or we have the guts to rebuild it with white list permissions on new filters.
PostPosted: Mon Jun 13, 2022 9:49 pm  (#7)
Recursive Transform is a white listed transform filter and Vignette and Supernova is a white listed on canvas gradient. The gradient is heavily modified though by other operations.
PostPosted: Sun Jul 10, 2022 12:13 pm  (#8)
id=2
xor aux=[ ref=2 id=1
gegl:svg-luminancetoalpha aux=[ ref=1  ] invert-transparency  ]
color-to-alpha color=#000000
Extract the brighthest colors from a layer. (This requires my custom Invert Transparency filter)
gimp:desaturate
invert-gamma
id=1
gimp:layer-mode layer-mode=hsl-color aux=[ ref=1 color-overlay value=#ffa2f8 ]
softglow brightness=0.1
bloom radius=3
exposure black-level=6 exposure=-0.4
noise-reduction
id=2
multiply aux=[ ref=2  ]
Glow Stick Effect. You can change the color by changing `color-overlay value=`
PostPosted: Mon Jul 11, 2022 10:26 am  (#9)
This operation blurs rough edges. It is similar to convulve stroke (set to blur). It requires my custom inner glow filter.
id=1
gimp:layer-mode opacity=100  layer-mode=split blend-space=auto composite-mode=auto composite-space=auto  aux=[  ref=1  innerglow grow-radius=6  radius=5 value2=#000000    ]
dst-over aux=[ ref=1 box-blur radius=1 median-blur radius=2   ]
I want to make this into a filter but I don't know how to link
Gimp:layer-mode.
Inner glow radius adjust the blur.
PostPosted: Wed Aug 24, 2022 9:13 pm  (#10)
1280x720 YOUTUBE THUMBNAIL SIZE - PREFERERED TO MAKE ONLY ONE LINE AND SELECT THE TEXT SO THE LINEAR GRADIENT WILL WORK.
This does not use any of my custom filters.
id=1 [ color-overlay value=#ffd44f gegl:dropshadow x=0.00  y=0.00 radius=1.00 grow-shape=circle grow-radius=1 opacity=1   color=#3b3b3b gaussian-blur std-dev-x=4 std-dev-y=3 emboss type=bumpmap depth=41 elevation=55 azimuth=12 unsharp-mask scale=1 gimp:threshold-alpha ]
bloom strength=25
id=noise2  divide    aux=[ ref=noise2 simplex-noise scale=12 invert box-blur radius=1  ]
id=1 multiply aux=[ linear-gradient start-color=#ffffff end-color=#000000 start-x=256 start-y=346 end-x=256 end-y=-54 ]
id=noise  multiply aux=[ ref=noise color-overlay value=#ffffff  noise-cie-lch chroma-distance=0 holdness=2 crop gaussian-blur std-dev-x=1 std-dev-y=1   ]
id=sg soft-light  aux=[  ref=sg softglow opacity value=0.7 crop dropshadow x=5 y=0 opacity=0.45 ]
crop
id=gold
opacity value=2
hue-chroma lightness=16  chroma=7
gimp:layer-mode layer-mode=behind aux=[ ref=gold  lens-blur radius=2 crop   ]
exposure exposure=-0.1
PostPosted: Wed Aug 31, 2022 9:46 pm  (#11)
Requires my custom hidden operation MCOL which comes with GEGL Effects and several other of my third party filters. This graph puts the rgb channels next to each other as layers, slightly moves themn and then adds glitch and scanline effects.
hue-chroma chroma=5
#virtual layer 1
id=2    ref=2  mcol value=#ff0900 translate x=27 y=-0 shift shift=1 shift shift=1 direction=vertical opacity value=0.85  ]
#virtual latyer 2
screen aux=[    gegl:over aux=[ ref=2 mcol value=#00ff00 translate x=-1  ]
#virtual layer 3
id=3   screen aux=[ ref=2   mcol value=#0000ff  translate  x=4 shift shift=0 shift direction=vertical shift=1  ]
#compostize alll (layer 4)
#layer 5
id=scanlines
soft-light aux=[ ref=scanlines  video-degradation  pattern=wide-striped opacity value=0.2]
soft-light aux=[ ref=scanlines  video-degradation  pattern=wide-striped opacity value=0.4]
#layer6 (adjustment layer of multiplication)
id=mul
unsharp-mask scale=0.5
#layer 7 noise
id=darknoise
gimp:layer-mode layer-mode=darken-only  aux=[ ref=darknoise noise-spread amount-x=133 amount-y=130 opacity value=0.28 ]
#layer8 adjustment hue chroma
brightness-contrast contrast=1.10
bloom strength=35
id=orton
gimp:layer-mode layer-mode=hardlight aux=[ ref=orton  gaussian-blur std-dev-x=20 std-dev-y=20 opacity value=0.74 ]
PostPosted: Fri Sep 02, 2022 10:38 pm  (#12)
This glitch effect works amazing on small images. Play around with it.
Requires my custom hidden operation filter MCOL which comes with GEGL Effects.
hue-chroma chroma=5
#virtual layer 1
id=2    ref=2  mcol value=#ff0900 translate x=15 y=-0 shift shift=1 shift shift=1 direction=vertical opacity value=0.85  ]
#virtual latyer 2
#virtual layer 3
id=3   screen aux=[ ref=2   mcol value=#0000ff  translate  x=2 shift shift=0 shift direction=vertical shift=1  ]
#layer 5
id=scanlines
id=mul
unsharp-mask scale=0.8
#layer 7 noise
id=darknoise
bloom strength=25
id=orton
gimp:layer-mode layer-mode=hardlight aux=[ ref=orton  gaussian-blur std-dev-x=20 std-dev-y=20 opacity value=0.30 ]
id=vapor gegl:over aux=[ ref=vapor ripple amplitude=29 period=0.8 angle=90
opacity value=0.4 ]
PostPosted: Tue Nov 29, 2022 2:47 am  (#13)
Here is the graph to do this. It requires a top and bottom layer import to GEGL Graph.
Top Layer
lens-distortion main=60
layereffects optioncolor=#00d9ff  opacitystroke=1 grow-radiusstroke=7  radiusstroke=20 xstroke=0 ystroke=0 colorstroke=#ffffff  depth=44 bevel1=99 radius1=4 blendmodebevel2=GrainMerge lightness=-43
hue-chroma hue=33 chroma=5 lightness=-3
Bottom Layer
lens-distortion main=80 zoom=6
color-overlay value=#007dff
id=1  ref=1 motion-blur-zoom center-y=0.5 center-x=0.5 factor=-7.0
gegl:opacity value=1
id=2 overlay aux=[ ref=2  emboss depth=4  ]
opacity value=9
opacity value=10
id=bevel
gimp:layer-mode layer-mode=multiply composite-mode=clip-to-backdrop opacity=0.10  blend-space=rgb-perceptual aux=[ ref=bevel bevel1=33 ]
PostPosted: Thu Dec 29, 2022 9:10 am  (#14)
https://twitter.com/LinuxBeaver/status/ ... 9912060929
Requires my Custom Bevel and Edge Extract. Many Graphs exist. This is way too complex to turn into a filter. Enjoy anyway.
id=1 gimp:layer-mode layer-mode=multiply opacity=0.54 aux=[ ref=1 color-overlay value=#8ff2ff   ]
noise-reduction iterations=2
id=2
gimp:layer-mode layer-mode=overlay opacity=0.6 blend-space=rgb-perceptual aux=[ ref=2 wind direction=bottom style=blast threshold=4 seed=13 strength=32 oilify mask-radius=2  softglow brightness=10 ]
id=3
gimp:layer-mode layer-mode=softlight blend-space=rgb-perceptual opacity=0.90  aux=[ ref=1 bevel radius1=1 ]
noise-reduction iterations=3
id=1 gimp:layer-mode layer-mode=overlay opacity=0.3 blend-space=rgb-linear aux=[ ref=1 edge-extract
wind direction=bottom style=blast threshold=4 seed=13 strength=21 oilify mask-radius=2  softglow brightness=10
custom-bevel  box=1 gaus=1 depth=3 blendmode=Overlay coloroverlay=#a3e9ff ]
id=2
id=3
id=2
id=3
id=4 gimp:layer-mode layer-mode=overlay opacity=0.2 blend-space=rgb-linear aux=[ ref=4 edge-extract
wind direction=bottom style=blast threshold=4 seed=13 strength=31 oilify mask-radius=2  softglow brightness=10
id=1 gimp:layer-mode layer-mode=hsl-color opacity=0.91 aux=[ ref=1 color-overlay value=#8ff2ff   ]
id=2
gimp:layer-mode layer-mode=overlay opacity=0.6 blend-space=rgb-perceptual aux=[ ref=2 wind direction=bottom style=blast threshold=1 seed=13 strength=1 oilify mask-radius=3   ]
id=3
noise-reduction iterations=4
opacity value=2.5
softglow glow-radius=2
ICE TEXT
id=n1
gaussian-blur std-dev-x=3 std-dev-y=3
color-overlay value=#52ebff
id=0 gimp:layer-mode layer-mode=hardlight aux=[ ref=0
emboss depth=5  ]
id=1 gimp:layer-mode layer-mode=hsl-color opacity=0.91 aux=[ ref=1 color-overlay value=#52ebff   ]
id=2
gimp:layer-mode layer-mode=overlay opacity=0.6 blend-space=rgb-perceptual aux=[ ref=2 wind direction=bottom style=blast threshold=1 seed=23 strength=1 oilify mask-radius=3   ]
id=3
opacity value=1.2
softglow glow-radius=1
hue-chroma chroma=10
id=5
gimp:layer-mode layer-mode=overlay aux=[ ref=5 edge ]
saturation scale=0.5
mean-curvature-blur iterations=7
hue-chroma lightness=-3
gimp:layer-mode layer-mode=split opacity=0.20 aux=[ ref=n1 gaussian-blur   ]
emboss depth=5  ]
id=2
id=3
opacity value=1.2
id=5
saturation scale=0.8
