It is currently Fri Oct 09, 2026 2:46 am
 Post subject: Legacy Mosaic in Gimp 2.10 because GEGL's version is so slow
PostPosted: Thu Jun 30, 2022 9:43 pm  (#1)
I took the binary of the mosaic from Gimp 2.4 and put in in Gimp 2.10's plugins and now I have the legacy mosaic filter.
I recommend others follow as the current mosaic filter is WAY TO SLOW!
 Post subject: Re: Legacy Mosaic in Gimp 2.10 because GEGL's version is so slow
PostPosted: Mon Jul 11, 2022 6:57 am  (#2)
Can you share it please, I'm very interested in it (I'm on Linux)
Patrice
PostPosted: Mon Jul 11, 2022 8:45 am  (#3)
By the GPL's regulations I have to link the source code which is in here somewhere when you search for mosaic.
https://download.gimp.org/pub/gimp/v2.4/
UPDATE-Source Code for 2.4's Mosaic is here.
https://cdn.discordapp.com/attachments/ ... 9/mosaic.c
Now here is the binary that only works on Linux. It goes in the normal plugins folder.
https://cdn.discordapp.com/attachments/ ... 196/mosaic
PostPosted: Mon Jul 11, 2022 3:23 pm  (#4)
Why did you take the 2.4 one? The 2.8 one should also work and its history says:
2013-09-22 Bug 677275 - Mosaic Filter produces ugly artifacts
This 2013 date is contemporaneous with the 2.8 versions (2012-2015).
Edit: Some Git magic shows that the latest fix is in 2.8.8.
The source of the latest 2.8 is here. On Linux you can likely download it and compile/install it with the gimptool utility.
PostPosted: Mon Jul 11, 2022 6:02 pm  (#5)
I have a chroot of Gimp 2.4 on my Linux machine that I made using a tool called CDE (Code Data Environment) back in 2019. I tried porting Gimp 2.8 using CDE and it failed. Only 2.4 worked.
CDE is like an ancient mid 2000s precursor to flatpak and appimage
PostPosted: Tue Jul 12, 2022 1:54 am  (#6)
Thanks for the binary, it's working fine :tyspin
Although it's way faster it has the exact same behavior -> the shadows hard to remove,
more to study for me => on everything opaque single color it draws the grid by making transparency (kind of color erase mode)... but if I check then uncheck it does it black even if my FG/BG are all white :puzzled .
Thanks, that nice, but how do you do that (compile)?
Patrice
PostPosted: Tue Jul 12, 2022 3:23 am  (#7)
AFAIK gimptool handles the compilation, it identifies the particulars of the local gimp installation and calls GCC with the adequate options...
PostPosted: Tue Jul 12, 2022 3:48 am  (#8)
ofnuts wrote:
And in English, like normal English, not programmer English, what do I need to do? :mrgreen:
Patrice
PostPosted: Tue Jul 12, 2022 5:55 am  (#9)
A Gimp 2.8 version ? I have one of those tucked away. From Gimp 2.8.22 Unzip, pop it into your user profile plugins folder. Find it bottom of Filters -> Distorts along with the other non-GEGL filters
linux-64bit-mosaic.zip [20.34 KiB]
Downloaded 158 times
PostPosted: Wed Jul 13, 2022 9:11 pm  (#10)
Thanks a lot rich2005
I did many tries and comparison, with the 2.4, the 2.8 and the GEGL...
The 2.8 is capable of drawing (while triangle is selected) and horizontal transparent line with the other black or white... :puzzled
2.4 and 2.8 are faster than GEGL, but can have some unexpected behavior depending on what color it is drawing, and may have some bug (like need to deactivate then activate again the FG/BG to get the right color) where GEGL is consistent and feel bug-less .
The drawing itself is the same as GEGL (that tiny shadow for example) but with GEGL you have more options which can "trick" that shadow to not appear.
In the end I did remove 2.4/2.8 as GEGL might be a little bit slower, but IMO it's a big improvement compared to 2.4, and 2.8... like night and day :bigthup
In all case thanks a lot @contrast_ and @rich2005 for providing these version, it was very useful to me for these tests :tyspin
Patrice
PostPosted: Sat Jul 16, 2022 12:17 am  (#11)
I still use the large preview Filters>Distorts>Mosaic filter and it works fine in Gimp-2.10.32 :bigthup
If anyone is interested i will upload the zip here.
