It is currently Tue Oct 06, 2026 10:36 pm
 Post subject: GEGL font name?
PostPosted: Sat Aug 27, 2022 1:29 am  (#1)
Does some one knows what's the font name used on the GEGL logo, the "closest" I can found are Circles New and may be Cairus (if you rotate the M as an E).
Or is it just a ... logo?
Patrice
 Post subject: Re: GEGL font name?
PostPosted: Sat Aug 27, 2022 1:59 am  (#2)
I believe it probably was never really a full font face, but more of a design of the 4 letters. :)
PostPosted: Sat Aug 27, 2022 2:26 am  (#3)
In the GEGL source code, there is a .SVG to produce the logo, and I can't find any hint that it comes from a font.
PostPosted: Sat Aug 27, 2022 2:29 am  (#4)
I have to admit though, it would be a pretty cool font. :) You could probably create it in Inkscape.
PostPosted: Sat Aug 27, 2022 9:00 am  (#5)
There likely was an original font that was modified as a logo for the circular features.
PostPosted: Sat Aug 27, 2022 9:25 am  (#6)
Circles New most likely if there was manipulation of a font face. A good test would be to open Inkscape and the text tool after installing Circles New and see if you can get similar results by moving the nodes around. :hehe
Then if you can get those results, create a font in Inkscape. :)
PostPosted: Sat Aug 27, 2022 10:01 am  (#7)
Yeah, it seems to be a logo only... So, I'm trying to make my own with the custom font tools from @Skinnyhouse :bigthup
:mrgreen:
Patrice
PostPosted: Sat Aug 27, 2022 11:26 am  (#8)
Just a quicky in Inkscape. :) Not spectacular but it will suffice. :)
Used the Circles New font type as a reference.
