It is currently Tue Oct 13, 2026 6:23 pm
Post new topic Reply to topic  [ 146 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 Post subject: GIMP Splashes
PostPosted: Sat Jun 18, 2011 2:59 pm  (#1)
This is what I use. Wanted a mint flavor.
 Post subject: Re: Splashes.
PostPosted: Sat Jun 18, 2011 5:13 pm  (#2)
I like yours more than mine. I need to stop being lazy.
PostPosted: Sun Jun 19, 2011 1:20 am  (#3)
I changed mine to say Pimp!
and also GMS9810, i really love that gold lettering text effect, would you mind a tutorial or a link to a tutorial if you read it off somewhere.
Thanks,
JFish
PostPosted: Sun Jun 19, 2011 6:46 am  (#4)
I love that steam punk look GMS!
Here is mine created in hopes of a soon new to be released version 2.8 :).
PostPosted: Sun Jun 19, 2011 1:36 pm  (#5)
Willy wrote:
Mine is default for 2.7.2, I don't know how to change and probably don't need to
It's really easy, it just takes a little explaining. In windows the splash is stored at C:\Program Files\GIMP-2.0\share\gimp\2.0\images. I recommend copying or renaming your original splash which is named gimp-splash.png. Then make your splash, name it gimp-splash.png and save it in place of the original. then when you restart gimp your new one will be there. There is a way to rotate splashes but i don't know how to do it.
Linux is basically the same process just a different path. i don't have Linux on so I don't off the top of my head know where it's stored but someone will tell you I'm sure. I have a dozen or so that i swiitch now and then. Right now as you can tell from my splash and sig I'm in my gold period.
PostPosted: Sun Jun 19, 2011 7:27 pm  (#6)
You don't "need" to know how to change it, but it still is fun!
My Sigs = My Photos
PostPosted: Sun Jun 19, 2011 7:30 pm  (#7)
But a tut on that would be cool because it's a really nice piece of art.
PostPosted: Sun Jun 19, 2011 11:11 pm  (#8)
Actually, GIMP first looks for C:\Documents and Settings\<user>\.gimp-2.6\gimp-splash.png (Check the log output in verbose mode.) If that fails, it then goes to the Program Files directory.
It's always safer to put things in your user directory instead of the program directory.
PostPosted: Mon Jun 20, 2011 9:10 am  (#9)
Linux has the gimp-splash.png file stored here:
/usr/share/gimp/2.0/images
but I may make a new one and place it here:
/home/cecilia/.gimp-2.6
I've noticed that everyone's splash image is a different res. I take it that's ok?
PostPosted: Mon Jun 20, 2011 11:04 am  (#10)
Your monitor will only display 72 or 96 dpi, anything else is a waste of resources but even if you make them 600 dpi they will work. They'll just be bigger than they needs to be.
PostPosted: Mon Jun 20, 2011 9:58 pm  (#11)
the original is 275 x 400 pixels.
I'll just keep whatever I design close to that. and while I have a ton of memory, I wouldn't want to waste it
PostPosted: Tue Jun 21, 2011 8:14 am  (#12)
i switch mine around from big ones to little ones. The one i have now is just a big one but I'll swap it in a while. You're right though, bigger ones tend to bog things down.
Well, as much as I'd like to sit and talk with my pals it's still very early and we're supposed to go pick blueberries so I'm out for a few hours.
PostPosted: Tue Jun 21, 2011 11:36 pm  (#13)
You can just place a bunch of them in your
user/gimp-2.6/splashes directory create the directory first. (splashes)
Place all your images there.
This will cause Gimp to load a different splash image each time it loads the program. :)
PostPosted: Wed Jun 22, 2011 7:13 am  (#14)
The splash should be always called "gimp-splash.png" but older gimp allowed to use also animated gif (if renamed "png" )
not sure if that is still possible (and anyway a heavy image will or slow down loading or simply would be not dispayed )
On gimptalk we had several contest for gimp splash screen (for gimp 2.4 and 2.6 ) many of them could be easily adapted to 2.7 or 2.8
PostPosted: Wed Jun 22, 2011 9:37 am  (#15)
Well, my point was that you can make a 275 x 400 pixel image at 72, 96, 300, 600 or whatever ppi. The higher the ppi, the more memory it takes to use it. Since monitors display 72 or 96 ppi anything more is wasted.
PostPosted: Wed Jun 22, 2011 9:39 am  (#16)
I knew there was a way but forgot how. Thanks.
PostPosted: Wed Jun 22, 2011 10:59 am  (#17)
To the contrary, GIMP and most other display-oriented programs like browsers and picture viewers only care about pixels when displaying to the monitor.
A 400 x 300 px splash image takes the same amount of memory and displays at the same size regardless of the ppi.
Check it out for yourself. Create and image and save it at different ppi. Then look at the file size and image size on the monitor.
Image Image
You can configure GIMP to display images in inches or mm, but the default is to display pixels.
The only programs that really care about ppi are printers and programs that are used primarily for creating printed output. (i.e. word processors)
PostPosted: Wed Jun 22, 2011 7:12 pm  (#18)
unless I actually have to print something - which doesn't happen very often - I never touch the default 72 dpi.
I'm almost strictly "RGB"
PostPosted: Wed Jun 22, 2011 7:19 pm  (#19)
Printers are concerned with DPI, monitors are concerned with PPI, they're not the same.
PostPosted: Thu Aug 11, 2011 9:42 pm  (#20)
please how I can do like this (GIMP) it's so nice
