It is currently Mon Nov 23, 2026 6:32 am
 Post subject: GIMP 2.10.38 Portable
PostPosted: Tue Jan 07, 2025 9:41 pm  (#1)
GIMP-2.10.38.7z.001
GIMP-2.10.38.7z.002
This is my own packaged version, Maybe someone wants to use it
Both files need to be downloaded. The total size is about 340MB. The decompressed size is about 1.83GB. The contents include
G'MIC 3.4.3
GIMP Animation Package 2.7.0
nufraw 0.43-3
hejiann beautify
BIMP 2.6
Liquid Rescale 0.7.2
Resynthesizer 2.0.3
MathMap 1.3.5(Quite old and a 32-bit plug-in, Some functions (color selection) may not work properly)
colorize-gimp
HN: Draw shape
...and some Scripts
After both files are downloaded, use 7-Zip to open the compressed file GIMP-2.10.38.7z.001 and extract the contents of the compressed file to the disk directory where you want to install it.
*** 2025/01/09
Sorry, Because the previous starter also set "USERPROFILE" in the "settings" folder, it cause GIMP cannot use some newly installed fonts
So if you find you cannot use newly installed fonts, You can download GimpLauncher.zip and replace the old GimpLauncher.exe
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
 Post subject: Re: GIMP 2.10.38 Portable
PostPosted: Wed Jan 08, 2025 12:46 am  (#2)
Hello
It's me again with wishes (not Christmas :hehe ) and questions:
1. You fixed Beutify - could you compile it without the console window and share it separately (this would make many users happy).
2. Is the GimpLauncher.exe starter your own? Why did you choose the name of the home directory 'settings' and not 'Preferences' (like in Sami versions, which many users are already used to).
3. Why did you choose the option with .debug (additional ~ 200 Mb) and 99% of users will never use it.
4. Why G'MIC 3.4.3 and not the latest version 3.5.0 ?
You didn't mention that:
- the archive is so-called multi-part (which many users have not encountered yet).
- it contains other surprises in the form of e.g. additional Brushes and Gradients, not to mention important plugins like LayerFX or RemoveBG.
Don't take my comments as criticism because I always appreciate new solutions. :tyspin :hi5
PostPosted: Wed Jan 08, 2025 3:45 am  (#3)
MareroQ wrote:
Hello
1. HejiannBeautifyEng.7z, GIMP-2.10.38.7z also updated, you can delete rip-border.exe and texture-border.exe
2.Yes, GimpLauncher.exe is my own starter
Why 'settings' and not 'Preferences', because 'settings' is shorter than 'Preferences'
3.I just copied the installed version whole directory, and package to portable version, had not check it's content, sorry, you can delete it
4.I used PC to watch TV, when test G'MIC 3.5.0 comic book filter, it cause TV lag, But it does not happen in version 3.4.3, so I change back to v3.4.3
PostPosted: Wed Jan 08, 2025 4:23 am  (#4)
Could you provide the source-code for beautify as well?
So linux people could try to compile it for their system?
PostPosted: Wed Jan 08, 2025 5:08 am  (#5)
Thanks for the quick response. :yes
I'm sure you've made a lot of users happy by adding HejiannBeautifyEng (but don't expect many thanks :clap ).
Miscellaneous comments:
The debug files are not only in bin, but also in each plugin subdirectory.
Instead of 'settings' the even shorter 'home' is used. :hehe
G'MIC 3.5.0 was compiled with CLANG and some filters are much faster - but I understand that this also causes other problems.
I'm using this starter (also for Gimp 3):
viewtopic.php?f=4&t=18926
PostPosted: Wed Jan 08, 2025 5:28 am  (#6)
You can download source code GitHub beautify
Only simple-border has the issue
simple-border.zip This is the file what I fixed
PostPosted: Wed Jan 08, 2025 5:48 am  (#7)
I install gimp-2.10.38-setup-1.exe again
It create .debug folder on first start
PostPosted: Wed Jan 08, 2025 6:09 am  (#8)
This is very strange.
By default, debugging is disabled in the installer.
You too? Have you checked 'Customize' (maybe it has this option checked from a previous installation)?
PostPosted: Wed Jan 08, 2025 6:19 am  (#9)
No, I just click install
so that is why it create .debug folder on first start
PostPosted: Wed Jan 08, 2025 9:24 am  (#10)
Thank you!
