It is currently Mon Nov 23, 2026 5:27 am
 Post subject: Gimp gimp-3.0.0_rc3 processing awkwardness
PostPosted: Thu Mar 27, 2025 9:00 pm  (#1)
With 2.10.38-r1, I could rectanglular select something, ctrl-c/ctrl-v, and then push the copied object into place.
Then flatten to fix. Reasonably quick.
With 3.0.0_rc3, I need to rectangular select, ctrl-c/ctrl-v, then go to move, move the object, flatten to fix,
then go back to rectangular select in order to release, then another flatten, then it releases. Takes a lot
longer.
This is on linux.
Any way to get 3x to work like 2x?
 Post subject: Re: Gimp gimp-3.0.0_rc3 processing awkwardness
PostPosted: Thu Mar 27, 2025 10:11 pm  (#2)
longer.
This is on linux.
With gimp 3.0 there are now more options in the Edit -> Paste menu. I suggest you want Edit -> Paste as Floating Data. This doesn't have a keyboard shortcut, so you can assign one using Edit -> Keyboard Shortcuts. To test this I just assigned Shift+Z so that now does what you're used to (obviously choose keys to suit you). More information on keyboard shortcuts here:
https://docs.gimp.org/3.0/en/gimp-help- ... tcuts.html
PostPosted: Fri Mar 28, 2025 12:06 pm  (#3)
Thanks! Works well.
