It is currently Mon Nov 23, 2026 12:49 am
 Post subject: Vulnerability on GEGL
PostPosted: Thu Jun 11, 2026 11:24 am  (#1)
It seems there is a vulnerability on GEGL, here the italian agency ammouncement, nobody know something about it?
https://www.acn.gov.it/portale/w/rileva ... ta-in-gimp
More info here:
https://share.google/aimode/6UyC7YLPpPsU7Mykj
 Post subject: Re: Vulnerability on GEGL
PostPosted: Thu Jun 11, 2026 12:32 pm  (#2)
It's in Gegl pre 0.4.68
The latest GIMP uses 0.4.70
PostPosted: Thu Jun 11, 2026 12:46 pm  (#3)
If using linux then some users might still be on Gimp 2.10.x and GEGL 4.48 so update if you can.
however, seen many like this over the years
quote This vulnerability resides in the GEGL library and could allow malicious users to execute arbitrary code on affected systems via appropriately crafted files.
Edit: I did not read far enough ;) a specially crafted, malicious file (such as HDR, GIF, or farbfeld)
yes, avoid those dubious gif animations.
PostPosted: Thu Jun 11, 2026 6:05 pm  (#4)
I can see they fixed a 'critical severity security issue' on their github page.
As quietreader noted they are up to gegl-0.4.70
PostPosted: Sat Jun 13, 2026 12:31 pm  (#5)
I believe I heard Pippin talk about this. He said that in theory a gegl graph could overwrite image files on a system. But I may have misunderstood him.
This implies a malicious user may be able to write gegl syntax that replaces all png/jpg/webps in the pictures folder with blanks.
