It is currently Sat Oct 10, 2026 6:44 pm
 Post subject: Gimp makes me want to scream!!
PostPosted: Tue Jun 22, 2010 12:18 pm  (#1)
I have to rant or I'll go off th deep end and kick small furry animals. Since the first time I saw Gimp I've been hooked on it but we seem to have this love hate relationship going on. If Gimp has one thing about it that I can't stand it's that every thing in it is in separate windows and is scattered all over the place. I use two monitors and at first thought it was cool to keep all of my pallets and tool bars on one monitor while I have the other one with the main window maximized on the other. Eventually I found that I just prefer it if everything is in one place so I put it all on my main monitor. Ok, great. What really makes me mad is always every few seconds I have to resize the main window. Every change to the drawing means that I have to resize and reposition the window, sometimes I spend more time moving and resizing windows than I do working on the drawing. I've been through every setting I can think of in preferences with no results. I've saved window positions, set it to save on exit, everything I can think of and still I spend more time resizing windows and dragging them out from under my main tool window. I WISH I knew how to make them sit still. I feel a little better now and all the small furry animals in the neighborhood can rest easier.
 Post subject: Re: Gimp makes me want to scream!!
PostPosted: Tue Jun 22, 2010 1:17 pm  (#2)
I hear your frustration. It is my understanding that gimp 2.8 will be an all-in-one desktop. Users will have the option of the 3-window option too.
My favorite trick is to click outside a gimp window and have them all minimize to the taskbar. I've gotten pretty good at avoiding that but I still do it occasionally.
PostPosted: Tue Jun 22, 2010 1:31 pm  (#3)
I've heard that about 2.8 too, I hope it's true, if it is then Gimp will only have one annoying thing left to it.
PostPosted: Tue Jun 22, 2010 1:39 pm  (#4)
I don't know if you've seen this, but some of those features are awesome.
http://www.gimpusers.com/tutorials/gimp-2-8-features-preview-april-2010.html
PostPosted: Tue Jun 22, 2010 2:09 pm  (#5)
I was doing pretty well waiting for 2.8 before, now after reading that link I want it NOW.
PostPosted: Tue Jun 22, 2010 3:08 pm  (#6)
:hehe
PostPosted: Tue Jun 22, 2010 7:48 pm  (#7)
didn't someone, maybe photocomix, make a virtual pin program...and would that keep the various windows sized and placed where you wanted them to stay?
PostPosted: Tue Jun 22, 2010 9:12 pm  (#8)
if so I'd really be interested in getting it.
PostPosted: Tue Jun 22, 2010 9:57 pm  (#9)
I found the link to his deviant art download of the pin by searching Gimp Talk..
http://photocomix-resources.deviantart. ... s-77124721
PostPosted: Wed Jun 23, 2010 5:38 am  (#10)
I have that little stick pin thingy but I don't find it that helpful cuz it does keep the window at the top but when you have to go back and forth to the tool windows it is a nuisance. It does stay permanently in your taskbar and easy to get at though...
PostPosted: Wed Jun 23, 2010 11:56 pm  (#11)
Not sure if you guys know or not but 2.6.9 is available for download...lots of bug fixes, no new added features. =)
Download page - http://www.gimpusers.com/gimp-download.php
Changes from GIMP 2.6.8 to GIMP 2.6.9, taken from
http://developer.gimp.org/NEWS-2.6
* Bugs fixed:
612618 - Font selection remains visible
622234 - gimp.desktop: image/x-psd in MimeTypes twice
622196 - Unportable test(1) construct in configure script
620604 - Description of "histogram" procedure is slightly inaccurate
541586 - Tool options not saved/loaded correctly?
614153 - Importing PDF files with long titles
600112 - blur-gauss-selective.exe crashes
599233 - Dialog of "Save as BMP" ignores changes which are not made with a mous
565001 - Text-Tool crashes when edit a 2.4.2 version XCF file
610478 - Layer preview suddenly stops getting updated
609026 - leaks shared memory
609056 - Exporting to Alias PIX format fails
608188 - a few strings in Save as... > Raw image data dialog are always in English
604820 - GEGL Operation "path" crashes GIMP
603711 - Crashes when using path tool
607242 - GIMP 2.7.0 fails to build against libpng 1.4.0
606372 - Saving to .ppm fails on indexed colorspace
605237 - the "Antialiasing..." message in the progress bar does not show translated
604508 - gimp-layer-new-from-visible should work from updated projection
* Updated and new translations:
Asturian (ast)
Basque (eu)
Burmese (my)
Catalan (ca)
Chinese (Hong Kong) (zh_HK)
Chinese (Taiwan) (zh_HK)
German (de)
Italian (it)
Latvian (lv)
Low German (nds)
Romanian (ro)
Simplified Chinese (zh_CN)
Slovenian (sl)
Ukrainian (uk)
Valencian (ca@valencia)
