It is currently Mon Nov 23, 2026 12:00 pm
 Post subject: Professional Photoshop user praises Gimp.
PostPosted: Fri Mar 23, 2012 11:13 pm  (#1)
I got so used to PS users saying they don't like Gimp that this came as a surprise.
http://www.youtube.com/watch?v=q-U6nDff12Y
 Post subject: Re: Professional Photoshop user praises Gimp.
PostPosted: Sun Mar 25, 2012 11:59 pm  (#2)
Could someone tell me what brush this is please? Because I can't find it. Gimp 2.6
I should know this...so embarrassing. :oops:
Thankyou.
PostPosted: Mon Mar 26, 2012 12:18 am  (#3)
It's a pretty old video by now, but it's a good one. :)
@Bar
It looks like a normal hard round brush (they are part of the default set, otherwise you can easily create your own using gimp's brush editor). He's using a tablet, which is why you see fluent variations in hardness as he works.
Griatch
PostPosted: Mon Mar 26, 2012 1:26 am  (#4)
Thankyou Griatch !
I see. It seems it's the tablet that is allowing for that brushed "pencil sketch drawing" effect.
PostPosted: Mon Mar 26, 2012 9:15 am  (#5)
GPS has an excellent graphite pencil brush that I use all the time as well as other pencil grades.
PostPosted: Mon Mar 26, 2012 6:23 pm  (#6)
Thankyou.
I thought you might like to try GPS (Gimp Paint Studio). It's a set of presets for gimp designed with the artist in mind. If you like your Gimp setup the way it is, don't use the rc files. I only copied the brushes and tool options to my Gimp setup. You can download GPS from here.
http://code.google.com/p/gps-gimp-paint-studio/
Here's a VERY quick sketch using only two presets.
PostPosted: Mon Mar 26, 2012 10:47 pm  (#7)
Oh cool thanks Erisian! :) I will try GPS (Gimp Paint Studio) later another day when I have time thanks.
You. Did. Not. Draw. That.
Did you? That sketching is incredible! Only some kinda professional could draw something like that.
PostPosted: Mon Mar 26, 2012 10:50 pm  (#8)
I'm not pro and wouldn't want to be - it would destroy my hobby. I drew that in about 3 minutes, normally for a face, I will work for about 7 or 8 minutes at the drawing stage before starting the painting. Here's a crop of something larger I'm working on.
PostPosted: Mon Mar 26, 2012 11:07 pm  (#9)
No way. I don't believe you. I couldn't draw either of those if I spent months on it and took an art class.
You little liar! I think I should click the "report this post" button and report your last post for giving false info ! You should be banned for that ! Image (kidding). Incredible excellent drawings.
PostPosted: Mon Mar 26, 2012 11:39 pm  (#10)
Thanks Bar.
