It is currently Mon Oct 12, 2026 6:38 am
 Post subject: Speed up GIMP operations?
PostPosted: Mon May 14, 2012 3:24 pm  (#1)
I'm not sure if this has been addressed elsewhere, but I'm curious: With the talk of GIMP becoming GEGL-based in future iterations, would that speed up operations (such as running a gaussian blur on a large image or rescaling multiple layers at once)? Or are those kinds of things just inherently time-consuming?
 Post subject: Re: Speed up GIMP operations?
PostPosted: Mon May 14, 2012 3:27 pm  (#2)
Mo Memory, Mo Memory, Mo Memory....if that doesn't work, buy some more memory. :hehe
PostPosted: Mon May 14, 2012 3:31 pm  (#3)
LOL I'm already rocking 16GB RAM with 10GB going to GIMP's tile cache alone :geek Maybe I'm just being picky.
PostPosted: Mon May 14, 2012 4:04 pm  (#4)
Jesus man, why even ask that question than! Yours set for a looooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooong time!
PostPosted: Mon May 14, 2012 4:21 pm  (#5)
...and your Gimp is too slow?!! :shock:
PostPosted: Mon May 14, 2012 4:33 pm  (#6)
Up to now it's been looking like GEGL would slow processing down, but to judge from this post of Partha's there may be some improvements possible: http://www.gimpusers.com/forums/gimp-us ... ssage66197
PostPosted: Mon May 14, 2012 4:37 pm  (#7)
Yes, something like a Gaussian blur is very compute-intensive. Even computing the result of two overlapping layers with partial transparency is rather CPU intensive (one multiplication/pixel/color channel). And try to use the perspective tool with preview on a 12Mpx photograph...
One point in favor of GEGL is that it makes it a lot easier to offload compute-intensive tasks from the main processor (CPU) to the graphics card (GPU). The latter is mostly a large set (fom 64 to over 2000 in current high end cards) of simple arithmetic processors that can work in parallel.
PostPosted: Mon May 14, 2012 4:41 pm  (#8)
That is precisely what I was wondering about, if using the GPU to perform operations like that within GIMP will be even faster than it is currently.
PostPosted: Mon May 14, 2012 4:45 pm  (#9)
OK. Now I'm really jealous! I'm running XP with a lousy 3GB of ram which, I'm told, is all that XP can drive. I need a new puter...... :tantrum
PostPosted: Mon May 14, 2012 4:47 pm  (#10)
Definitely. The hitch is that accessing the GPU is done through system interfaces that aren't the same in Linux/OSX/Windows so the ports are going to be more difficult.
PostPosted: Mon May 14, 2012 5:36 pm  (#11)
Kevin,
I used those optimizers on my builds and now Gimp seems to be pretty "zippy" on 8G RAM (64-bit).
PostPosted: Mon May 14, 2012 9:41 pm  (#12)
I have always said Parthas builds seem to be faster than the dev releases. :)
Even on my 1GIG RAM machine with Windows XP they are pretty quick. As long as i do not bog them down with brushes, and patterns to load.
