It is currently Fri Oct 16, 2026 12:49 am
 Post subject: LiberKey and Gimp 2.8
PostPosted: Sun Jun 24, 2012 10:26 pm  (#1)
I found this post at the LiberKey forum. It's a fix for "zlib1.dll" and "libgimpui-2.0-0.dll" errors with LibeKey Gimp 2.8. I thought it might be of interest to anyone running the LiberKey version of Gimp or troubleshooting for someone around here.
http://www.liberkey.com/forums/support- ... =fr#p34507
LibreKey Forum Post wrote:
Re: Gimp 2.8 error when starting
de ricky » 10 Mai 2012, 14:34
Hello,
(Bad link in quote removed)
To resume, copy all the dll's from : Apps\Gimp\App\Gimp\bin to Apps\Gimp\App\Gimp\lib\gimp\2.0\plug-ins
It's a problem with the liberkey version, the portableapps version works without problems.
 Post subject: Re: LiberKey and Gimp 2.8
PostPosted: Mon Jun 25, 2012 12:13 am  (#2)
bad link ,404 error
PostPosted: Mon Jun 25, 2012 1:22 am  (#3)
The first link I listed sending you to the original LiberKey post should work. The link in the LiberKey forum quote I marked with the red arrow is the bad guy removed.
cron
