It is currently Mon Nov 23, 2026 11:12 am
 Post subject: whats the best technique to make diagonal stripes ?
PostPosted: Thu Aug 23, 2012 8:25 pm  (#1)
i love these industrial type of looking, yellow/black diagonal stripes
whats the best technique for creating them ? (by hand, with filters, scripts, paths, etc.)
i just made these by using rectangular selections, filling them with black and yellow and then rotating by 45°, then duplicating the layer and filling in the gaps
 Post subject: Re: whats the best technique to make diagonal stripes ?
PostPosted: Thu Aug 23, 2012 8:35 pm  (#2)
patterns
PostPosted: Thu Aug 23, 2012 8:54 pm  (#3)
Another way is to use the Blend Tool with the Hard Edge gradient. Set the Shape to Linear, and Repeat to either Sawtooth or Triangle, then "paint" your stroke perpendicular to the direction of your stripes. The length of your stroke is either the width of your stripes (Triangle repeat) or half their width (Sawtooth). Hold down the CTRL key while you paint to make sure your stroke is at exactly a 45 degree angle.
PostPosted: Thu Aug 23, 2012 8:55 pm  (#4)
patterns
thanks molly, that came to my mind after i posted this thread
but i've never tried that before
i think there was a good youtube tutorial how to make patterns, i remember checking out
will give it another go !
thanks saulgoode for the explanation !
it sounds a bit difficult after reading it once
i will definitely check this out, too
there is still much to learn for this padawan :( :mrgreen:
PostPosted: Thu Aug 23, 2012 9:05 pm  (#5)
This pattern warning 20x20 actually comes standard with Gimp. :)
PostPosted: Thu Aug 23, 2012 9:35 pm  (#6)
i remember seeing that....came in handy as a template when i tried to make the pattern, thanks Rod !
i made a pattern 300x300pixels, black and transparent, so you can use it with a variety of colors
diagonal_Stripes_300x300_transparent-black.pat [351.62 KiB]
Downloaded 863 times
saulgoode wrote:
Another way is to use the Blend Tool with the Hard Edge gradient.*snip*
that was actually quite simple and much quicker than making a pattern !
also you have control over the angle of the stripes
COOL ! :bigthup
thanks again saulgoode !
PostPosted: Thu Aug 23, 2012 10:17 pm  (#7)
Yeah i agree Saulgoode is very knowledgable with Gimp. :)
PostPosted: Tue Dec 17, 2024 4:42 pm  (#8)
This is the hardedge gradient method for making a stripped pattern.
As originally described by saulgoode
View saulgoode's Post By Clicking Here.
Select a foreground and background colors.
In this case the colors are yellow and black respectively.
Within the gradients dialog.
Mode should be normal.
Set the shape to liner and set the repeat to sawtooth wave.
Stretch out the gradient form one side to the other.
Long stretch will give less strips, shorter gives more.
It's that simple!
PostPosted: Tue Dec 17, 2024 5:11 pm  (#9)
My plugin stripes does this
https://github.com/LinuxBeaver/GIMP-GEGL-PLUGIN_Stripes
PostPosted: Tue Dec 17, 2024 5:13 pm  (#10)
contrast_ wrote:
How simple is it?
PostPosted: Tue Dec 17, 2024 5:26 pm  (#11)
contrast_ wrote:
How simple is it?
easy!
Go here, https://github.com/LinuxBeaver/GIMP-GEG ... s/releases
You put the binary (dll) in C:\Users\USERNAME\AppData\Local\gegl-0.4\plug-ins and restart GIMP. Go to GEGL Operation and look for "Stripes"
if on GIMP 3 you still have to put the binary in the location above, but you can just search "stripes" after running the plugin you'll see its simple.
PostPosted: Tue Dec 17, 2024 5:46 pm  (#12)
contrast_ wrote:
easy!
The tools to do this are already available out of the box.
My point is,
that this is a very simplistic GIMP function,
that anyone can utilize.
It's a no-brainer.
PostPosted: Tue Dec 17, 2024 6:00 pm  (#13)
contrast_ wrote:
easy!
My point is,
It's a no-brainer.
In GIMP 3 RC1 its re-editable when using the plugin but not the gradients tool. I agree too that i'd be better If GIMP could do it non-destructive out of the box with the gradient tool.
PostPosted: Tue Dec 17, 2024 6:18 pm  (#14)
Don't get me wrong GEGL is cool and all.
As far as out of the box functionality,
this has to be the least complicated method that anyone can use.
Other them dropping in a pattern.
PostPosted: Tue Dec 17, 2024 8:50 pm  (#15)
The gradient tool in GIMP uses GEGL, a special op called (gimp:gradient) but its set to apply destructive because GIMP 3 doesn't have the ability to recall gradient coordinates on canvas.
PostPosted: Tue Dec 17, 2024 9:03 pm  (#16)
Nothing was destroyed by creating this pattern using the hardedge gradient method.
PostPosted: Tue Dec 17, 2024 9:39 pm  (#17)
:lol The word "destructive" is a graphics design term. "destructive" means the same thing as raster. It can't be re-edited. Its applied as pixels only.
The plugin "stripes" can be edited again after applied on canvas in GIMP 3. Therefore it is termed "non-destructive"
Pic attached shows Stripes plugin as a "non-destructive" layer effect
PostPosted: Tue Dec 17, 2024 10:00 pm  (#18)
The text in GIMP 3 is called non-destructive graphical text because it isn't just pixels and can be re-edited.
PostPosted: Tue Dec 17, 2024 10:04 pm  (#19)
I get all that.
This method isn't anything new.
This thread has already demonstrated how easily this pattern can be achieved.
Another way right out of the box to make stripes with any gradient.
Would be to use "posterize".
PostPosted: Tue Dec 17, 2024 10:07 pm  (#20)
I get all that.
cool I didn't know posterize could do that. Thanks for showing me
