It is currently Thu Oct 15, 2026 12:45 pm
 Post subject: i need help with fonts...
PostPosted: Thu Aug 30, 2012 3:59 am  (#1)
i know you can make your own brushes in gimp. i know you can down load brushes into gimp but here is my question....can you add fonts to gimp as well or not...i need a certain font for a picture i want to do...i will find a picture of the style of font i am looking for...and post it here...thanks to anyone who can help me....
 Post subject: Re: i need help with fonts...
PostPosted: Thu Aug 30, 2012 4:05 am  (#2)
There is a Gimp Font folder.
C:\Users\[user]\.gimp-2.8\fonts
PostPosted: Thu Aug 30, 2012 4:08 am  (#3)
here is the type of font i am looking for...i am not sure the name of this font..i think it maybe be hobo or hobby headline...like i say i am not sure about the name of the font but here is what i am looking for....
.Image
if you can't download fonts is there one like this in gimp already.... please i hope someone can help me...
PostPosted: Thu Aug 30, 2012 4:10 am  (#4)
thanks for your help. is there one in gimp 2.6 that's what i am using...
PostPosted: Thu Aug 30, 2012 4:29 am  (#5)
If I remember correctly, Gimp comes with no fonts, instead Gimp uses the system fonts you already own (installed or not, btw).
Now, if you're looking to identify a font, you can try both methods:
http://www.myfonts.com/WhatTheFont/
http://www.identifont.com/identify.html
PostPosted: Thu Aug 30, 2012 5:06 am  (#6)
i figured it out.....thanks guys.... :yes :yes :yes
PostPosted: Thu Aug 30, 2012 10:06 am  (#7)
not sure if you can see that:
http://www.myfonts.com/WhatTheFont/resu ... &x=91&y=46
whatthefont search says the font is called Hobo
PostPosted: Thu Aug 30, 2012 10:16 am  (#8)
You can get the font here.
http://www.coolfonts.info/font-1360-hobo.php
PostPosted: Thu Aug 30, 2012 10:35 am  (#9)
the slogan of that website is gold
Tired of browsing through thousands of fonts? Download 10,000 free fonts at once!
yeah, im really tired of going through 1000s of fonts,
id prefer to go through TENTHOUSAND FONTS on my HD
see ya, next year :rofl
PostPosted: Thu Aug 30, 2012 10:44 am  (#10)
At least on Windows gimp ,regardless of the setting used (, even if that path is unchecked in the preferences ) load always all the font in C:Windows/font
but you may add fonts to be read only by gimp locally, inside that font empty font folder, in case set the path using Edit/preferences/folder/font...once done remember to click ok before exit from preferences ( i suggest because i often forgot with very delusive results :gaah )
That Gimp font folder may be useful also for fonts that doesn't show up...may happen that they will work if copied in that font folder
(in any case there are a few fonts that for some reason gimp can't support, but should be rare cases )
