It is currently Wed Oct 14, 2026 12:33 pm
 Post subject: Can't open .psp files?
PostPosted: Sun Sep 09, 2012 3:49 pm  (#1)
This is what I get when I try to open a .pspimage file.
Is there something I need to do first?
 Post subject: Re: Can't open .psp files?
PostPosted: Sun Sep 09, 2012 3:59 pm  (#2)
as far as i understand it, you cant open these filetypes with Gimp
but a quick google search told me, there is a plug-in for this
hope that helps until somebody more knowledgable comes to give you some advice
EDIT: wait, you have this plug-in already installed ?
PostPosted: Sun Sep 09, 2012 4:02 pm  (#3)
Not that I know of...
PostPosted: Sun Sep 09, 2012 4:04 pm  (#4)
well but your error message says: "paint shop pro image plug-in could not open image"
PostPosted: Sun Sep 09, 2012 4:06 pm  (#5)
Yeah, I know. The only psp plugin I have is pspi.exe.
PostPosted: Sun Sep 09, 2012 6:33 pm  (#6)
If the PSP version is an old version ... 7 or earlier I think, gimp can't open them. I belong to a newsgroup that they offer PSP tubes and some I can open and some I can't. If I really want one of them, I ask if they'll make the image a .png image for me.
PostPosted: Sun Sep 09, 2012 8:32 pm  (#7)
I don't have PSP on my machine, but get the same error message trying to open a PSP v8.0 file in Gimp 2.8x. My work around was to open the PSP file in Zoner Photo Studio and convert to TIF. No layers but everything else was OK.
PostPosted: Sun Sep 09, 2012 8:55 pm  (#8)
As a workaround, you can open a psp with xnview and convert it, I think. I took psp out of my life years ago so I don't have a sample to test it.
PostPosted: Mon Sep 10, 2012 11:40 am  (#9)
Aww man. I'm a tagger so if the file is layered, I really need it to stay in layers to delete the credits and such. Guess I'll just have to take it to the creator of the file.
Thanks everyone!
