It is currently Tue Oct 13, 2026 9:33 pm
 Post subject: Does anyone else still use GreyC?
PostPosted: Wed Oct 03, 2012 11:54 am  (#1)
Yup.
I guess I' m a bit old-fashioned but I still use the old GreyC filter. I never really bothered downloading G' MIC and even went through the trouble of importing it from 2.6 to 2.8 when it came out a couple of months ago :mrgreen:
Is G'MIC worth it though? I also have FX Foundry which seems to be everything I ever needed.
 Post subject: Re: Does anyone else still use GreyC?
PostPosted: Wed Oct 03, 2012 1:31 pm  (#2)
well "greyc" is 1 of the more then 300 filters included in gmic
about Fx Foundry ,scripts miss the preview and that in most cases is a severe handicap
PostPosted: Wed Oct 03, 2012 6:23 pm  (#3)
Personally, I can't do without G'MIC - especially it's thin brush smoothing which I use a lot. (PhotoComix' creation) Give it a whirl. There are many useful and fun filters in there.
PostPosted: Wed Oct 03, 2012 8:51 pm  (#4)
In a word, YES. G'Mic is definitely worth it.
PostPosted: Thu Oct 04, 2012 12:47 am  (#5)
I pretty much canned GreyC and replaced it with G'MIC since my main use for GreyC was fake smudges and G'MIC presets do more then a better job for me. :)
PostPosted: Thu Oct 04, 2012 4:21 am  (#6)
Okay, seems like I AM the only one :mrgreen:
I will check it out now, though.
PostPosted: Thu Oct 04, 2012 8:46 am  (#7)
I still do! I've never looked into G'Mic... wonder if it'll work on my Mac?
PostPosted: Thu Oct 04, 2012 9:27 am  (#8)
The easiest way to check out G'mic would be to download one of the portable versions that include G'mic. Partha's, Photo Comix, and Samj versions would work. That way you don't change your existing setup until you decide.
Myself, I am only running portable versions so I can access all features of Gimp.
PostPosted: Thu Oct 04, 2012 11:57 am  (#9)
Where can I find those versions bilbo? I googled but couldn' t find anything that made any sense to me. I' m not an expert on computers...
And what would it change about my existing setup if I downloaded something else?
PostPosted: Thu Oct 04, 2012 12:08 pm  (#10)
on this forum !
see gimp newa
anyway for mine
http://sourceforge.net/projects/gimp-packagers/files/
the first from the top is for 64 bit the 2nd 32bit
PostPosted: Thu Oct 04, 2012 1:14 pm  (#11)
Ohh, okay, cool. Thanks Photocomix!
PostPosted: Thu Oct 04, 2012 1:22 pm  (#12)
Okay, as I read through these threads, I see people referring to different filters in their GMIC's that I don't have. Can anyone explain to me how to get and install them? Thank you!
“For man, as for flower and beast and bird, the supreme triumph is to be most vividly, most perfectly alive.” David Herbert Lawrence
PostPosted: Thu Oct 04, 2012 5:41 pm  (#13)
I also never took the time to explore G'mic, so I'm still using GreyC (mostly to save noisy photos from the junk).
