It is currently Mon Nov 23, 2026 11:59 am
 Post subject: JPEG2000 for GIMP ? {Deb Linux}
PostPosted: Mon Oct 04, 2010 1:48 pm  (#1)
Wasn't really sure where to post this, but...
I was wondering if GIMP will ever support JP2s, or if there is some arcane reason why it won't. (proprietary licensing weirdness, political wackiness, technical incompatibility, etc.)
For all I know, it may already.
Please note that I run a Debian Linux platform... The Lenny package. Latter day Lenny, but still, it's not bleeding edge.
IF it won't, or doesn't or something, a suggestion as to how to read them in a linux platform would be most appreciated.
I know this latter part is dangerously close to being off-topic, but... the first part is, at least, about Gimp.
Thanks....
~DorBluBrd :gimp
 Post subject: Re: JPEG2000 for GIMP ? {Deb Linux}
PostPosted: Mon Oct 04, 2010 1:59 pm  (#2)
GIMP already supports jp2 files Dorthy. :)
edit:
Come to think of it, I might have downloaded a GIMP plugin for this; don't use it at all and my version doesn't appear to support transparencies unfortunately. Went to the registry and found this thread; might be of help to you. :)
http://registry.gimp.org/node/9899
PostPosted: Sat Oct 09, 2010 9:07 pm  (#3)
Well, I looked at the thread, and thought about it a while... then went back and reread it.
It looks like it supports .jp2 files... if you happen to be a hacker and can fix the bugs with it. Oh, and you have a Windows machine. Which... I don't.
Now, it's possible that I haven't properly digested the implications of the discussion. I am not a programmer, and am a step up, perhaps, from a super-user. Sure I have studied some basic programming, even written a few programs... but apparently not enough to help with this.
However, things get easier now that my computer knows how to view these images.
I can strip out individual files from the archive, then open them with Kview to save them in a pcx format, which, hooray(!), my version of GIMP can read. I don't know how much loss one gets from doing that, but it looks good from my initial test. As an added bonus, my system doesn't act like it's digesting a particularly large meal.
I didn't want to try a standard JPG, largely because ginormous files in JPG have lots of cpu overhead, and can cause... problems. Hence, why jp2 was created in the first place. I was thinking of TARGA format, too, because I have heard that it is supposed to be good for large cumbersome files, but I have never tried it.
Ooops, sorry about the (possible) drift. Should I start a new topic before going on a rip about file formats?
If so, I can install a link here in case others want to follow the progression. :)
PostPosted: Sat Oct 09, 2010 9:50 pm  (#4)
how much large ?
PostPosted: Sun Oct 10, 2010 12:06 pm  (#5)
Let's see... the largest is 973.2 KB, (gimp says 28.2 MB)and the smallest is 602.3 KB. So far. There's a huge batch of them that I am processing.
It is a quarto size, high-definition scan of a book published in 1689. "Devises et Embleme" is it's name.
Googlebooks is awesome. You can find such nifty stuff in public domain...
Upon further investigation, the translation into .pcx turned the images into 72 dpi by default. The originals looked to be much higher quality, probably 300 dpi if not higher. The program that can read the jp2s is not terribly sophisticated in terms of meta data... and I don't know how accurate that number is.
So my current method works for display on the web... not sure for much else. :melt
This is not the quality of image I want for processing. It looks... a touch blurry to me.
I mean, if I were just posting this as-is, I'd just dial in the sharpen and be done with it.
The irony is, I've worked with images this size before, and the machine seems to struggle more with translation of jp2 than other formats (mostly xcf... I get layer-crazy sometimes, esp working with multilayer text) Note that my sample is just a small portion of the total image size... a full page would be a bit much. Especially since the edges of the book are also scanned, and the bindings and have lots of rust and graphical features that adds to the bulk of each image.
So size is probably not as big of a deal as it could be. I'll try regular jpgs and targa and see what happens.
PostPosted: Sun Oct 10, 2010 1:00 pm  (#6)
PS you forgot a very important info
In what format you saved your scanner ? (jpg, tiff , png)
and your scanner saved as greyscale , or RGB ?
OR you edited the scanned images in gimp and you are processing xcf files ?
i really don't think that with max 973.2 KB they may be "large cumbersome file"
Almost everything i do is more then 2MB , once flattened and exported as png,( much more as XCF file,)
supposing you have a not a very old computer and 1GB or at least 500MB of Ram you should not have any problem to process similar files
I will discorage use jpg2000, is a cool format but not sufficently commune, i will just use png when is needed highest quality and...well just plain jpg (for better quality..just raise the quality from default 85, to 95 )
PS for Targa there is a similar situation then for jpg2000, may be good but i am not sure will be displayed by browser.
Usually in linux for this kind of batch is "imagemagick" the tool for the trade
If you get Wine you may also install "irfanview" that also may convert between the most different graphic format in batch.. but offer a intuitive graphic interface.
PostPosted: Sun Oct 10, 2010 4:30 pm  (#7)
I did not scan the images myself. I downloaded a pre-scanned "book" comprised of high quality jp2 images, sourced from Googlebooks. I don't have a choice about formats... it was either jp2 or PDF, and the image quality in PDF is not high enough.
I am planning on backtracking to the download site, and see if I can find any raw formats or see if they have more information about what quality the images were scanned at.
PostPosted: Sun Oct 10, 2010 5:04 pm  (#8)
i see
it seems you have no much choise
The best support for Jpg2000 (data from http://it.wikipedia.org/wiki/JPEG_2000 )
is offered by Xnview that is a free windows program that should work in linux with wine (there was a unix port but is quite inferior to the win one)
Follow Irfanview (for sure will work in ubuntu with wine, already tested )and the 2 classic unix tool ImageMagick and GraphicMagick
But gimp should be able to read, (not write ) jpg2000 without any plugin, the plugin should be needed only to save
(anyway for batch operation any other of the program i quoted is much more adapt then gimp )
PostPosted: Sun Oct 10, 2010 6:50 pm  (#9)
I thought I had JPEG2000 for my Gimp (Windows) and now can't find it. Hmmm?
My Sigs = My Photos
PostPosted: Sun Oct 10, 2010 11:37 pm  (#10)
Doesn't "Seperate+" filter suite have JPEG 2000 support? Or is Seperate just for printing?
PostPosted: Mon Oct 11, 2010 12:58 am  (#11)
Strange. I tried to open the jp2 file, and it... just failed. No errors, no nothing. I will experiment with it again, and see what happens. Could have been a bad IO day or something.
Is there a way to look at the error log live, say through script-fu or something?
PostPosted: Mon Oct 11, 2010 1:33 pm  (#12)
BTW, while the most recent version of Gimp probably does read jp2's... mine does not. I am running GIMP 2.4.7, BTW.
It doesn't recognize the file format at all. Under the "all images" filter in the open dialog, it doesn't even show the listings for my jp2s.
I tried opening from the "all files" filter, and it failed.
I'm unlikely to be able to update GIMP in any significant way (version-wise) due to a dependency nightmare I'd rather not go into. That goes well beyond the scope of this post.
Huh. I'll have to look at the +Separate suite. If it opens things independently from Gimp itself, it just might work.
I'm also going to kick my local sys-admin and see if he can see a way clear to updating the thing, but knowing the outlines... that's probably going to have to wait until the new server comes in.
Sigh.
Still... :gimp anyway.
PostPosted: Mon Oct 11, 2010 2:04 pm  (#13)
i fear that separate plugin is only for CYMK separation
I could not understand your problem to install a more recent version of gimp ( don't try to update in case just unistall and reinstall ) but from your message i suppose you are not in control of the computer that has another admin.
anyway should be no problems of dependency (except from the Boss opinion, if you have no control of the computer )
