It is currently Sat Oct 17, 2026 10:15 am
 Post subject: whats the best and fastest way to render this picture ?
PostPosted: Wed Dec 05, 2012 9:02 pm  (#1)
so here is the classic problem, how do i get rid of the background so that the guy remains ?
layermask ?
path tool ?
highpassfilter ?
channel mixer ?
quickmask ?
eraser tool ?
etc.
the t-shirt part is probably the easiest but the dark skin against the dark background is kind of tricky
what is the best and most effective technique for that particular picture ?
your opinions and secret techniques pls ;)
 Post subject: Re: whats the best and fastest way to render this picture ?
PostPosted: Wed Dec 05, 2012 10:18 pm  (#2)
I would use the path tool and finish the fine details with a quickmask. Relatively quick work even counting the time to zoom in to the 2-3 pixel range for a neat job.
PostPosted: Wed Dec 05, 2012 10:30 pm  (#3)
If you just want the guy I can do it in less than 3 or 4 minutes with Xara Designer
PostPosted: Wed Dec 05, 2012 11:05 pm  (#4)
nah GMS, just curious about Gimp techniques
PostPosted: Wed Dec 05, 2012 11:23 pm  (#5)
i like layermasks, 'tstandiford' has conditioned me forever with his tutorials i guess, lol
so i rendered the picture in four parts
part one: body with a standard layermask (you know, b/w copy, values)
part two and three: selected the arms with the path tool and used a selection layermask
part four: bits of the dreadlocks and beard (painted the layermask by hand)
PostPosted: Thu Dec 06, 2012 12:50 am  (#6)
Nice technique, Esper!
For the same task in my recent post here I used Foreground select tool and then Fuzzy select tool to remove what is left from background (I usually set threshold to 20-25 and press Shift key to add to selection). In the end I always alpha select, shrink by 1 pixel and invert-clear to make the edges clean. Fast method for less accuracy and takes about 4-5 minutes.
PostPosted: Thu Dec 06, 2012 10:47 am  (#7)
interesting K1te !
i tried it but used the foreground selection tool to turn the selection into a layermask, because i felt that would give me more control
it was indeed pretty quick, but there was a look of cleaning up to do, with the fuzzy select tool
getting the edges clean is always the biggest problem, so your technique with shrinking by 1px is a good choice i think
