It is currently Sat Aug 15, 2026 6:10 am
 Post subject: JGimpOS - managing scripts
PostPosted: Fri Dec 21, 2012 3:17 pm  (#1)
I've written a tool for managing all the script files (.scm)
The tool is written in java. It works with:
- java 1.6 and above
- Windows, Linux
The reason for this tool was:
- scripts go to the gimp menu, that the programmer wanted. I maybe want an other menu. This was the main reason.
- when sometime using scripts, I want to know, which script it is.
Start the tool.
Load script(s)
Load directories containing scripts
Drag&Drop scripts/directories to tree
Drag&Drop scripts in the tree between menus (the way to change menus)
Create/Delete new menus
Change menu name
Change description
Changes are saved in the script, backups are written.
Make sure you have permissons on scriptdirectory.
No guarantee, no warrenty that it works for you, or with your hard- and software or leaving your scripts alive.
If this tool works for you: great. If not: not great.
Hatti
updating(1): 22.dec 2012
JGIMPOS-2.0.1.ZIP [127.82 KiB]
Downloaded 313 times
 Post subject: Re: JGimpOS - managing scripts
PostPosted: Fri Dec 21, 2012 4:34 pm  (#2)
sounds interesting, Onkel Hatti
PostPosted: Fri Dec 21, 2012 6:20 pm  (#3)
Works like a champ :bigthup
PostPosted: Fri Dec 21, 2012 7:12 pm  (#4)
okay, so this works on its own, i was under the impression i have to put it in my scripts folder
PostPosted: Fri Dec 21, 2012 7:29 pm  (#5)
Thank you so much @Onkel Hatti, i finded also duplicates scripts :coolthup . I think that it would be interesting also for plugins .py .
:tyspin :bigthup
PostPosted: Fri Dec 21, 2012 11:14 pm  (#6)
Revelation!
Two questions:
1. File - Load Directory-only 99% (the rest are errors ?)
2. What does this mean (script error...)
PostPosted: Sat Dec 22, 2012 12:08 am  (#7)
I noticed the 99% load as well, I can't replicate. My log also showed lot's of unknown errors.
If you want to know where the log file is look for "jgimpos.log" in the users folder.
For example in Win,
C:\Users\Odin\.jgimpos\jgimpos.log
Ed.,
The error might be gimpfx-foundry scripts.
PostPosted: Sat Dec 22, 2012 1:19 am  (#8)
I've started the tool but I only get a flash and nothing happens there must be something I am missing, do I need to install the .jar file somewhere
PostPosted: Sat Dec 22, 2012 1:52 am  (#9)
You need Java installed. I have 7.0.x.
PostPosted: Sat Dec 22, 2012 2:20 am  (#10)
Odin I have 32bit java 7 update 10 installed and as you can see in the image I uploaded the jgimpos-2.0.1.jar file is set to be opened with Java(TM) Platform SE binary, but all I get is a flash in the pan :gaah
PostPosted: Sat Dec 22, 2012 2:48 am  (#11)
I have uploaded a newer version (first post)
@MareroQ:
1. I don't know. try the newer version. The log should say which script could not be loaded. The progress should go up to 100% (in the newer version file-number/total-files) This is reset, if clicked anywhere in the window.
2. It's not a bug, it's a feature :-) The menu of the script ends with "/". Thats not usual, so the program "thinks", there must follow an other menu entry, so it creates a new menu entry in the tree structure, but with no name... I fixed it, so "empty" menus are not longer created.
I fixed up the log. It was written, whenever a script was loaded/saved but when tehre was no error, it says only the event time, the severity level (ERROR) and then the errors. Mostly nothing. Thats confusing.
Now, if there is no error, the log is not written.
@Graechan:
Sorry, I can't help you. The program can be anywhere, just double click on it.
Maybe you can try start terminal/cmd window, change directory to where jgimpos-2.0.1.jar is, type:
javaw -jar jgimpos-2.0.1.jar
watch the error.
PostPosted: Sat Dec 22, 2012 5:34 am  (#12)
Thank you very much.
This is very useful !!!
PostPosted: Sat Dec 22, 2012 1:04 pm  (#13)
Hatti, Along with the menu functions I find the Parameter list display helpful. The program provides a very interesting way of looking at your Gimp scripts. I also like the View Script extra, how about an extra that opens your text editor?
PostPosted: Sun Dec 23, 2012 12:46 am  (#14)
I am not so sure I have the correct Java installed so if someone could give a URL for the java download it would be appreciated
PostPosted: Sun Dec 23, 2012 1:24 am  (#15)
www.java.com
The JRE (Java Runtime Enviroment) is good enough.
PostPosted: Sun Dec 23, 2012 1:42 am  (#16)
Then It's a real head scratch-er as when i select the file from my desktop nothing happens and the link you gave me informed me that I already had the latest version
Are there any windows settings that should be checked to ensure they are correct and that the .jar file will call on java to open
PostPosted: Sun Dec 23, 2012 2:14 am  (#17)
You're using Windows 64, Graechan. My advice - download and install both 32- and 64-bit versions of Java 7.10 here
If Java installers confirmed successful installations, there should be no problem running JGimpOS.
PostPosted: Sun Dec 23, 2012 3:19 am  (#18)
Right click the file, Open with and see what there. Here's mine.
PostPosted: Sun Dec 23, 2012 4:58 am  (#19)
Ok, I opened it with Java and got this. I click Extras and the box comes up empty, I click filters and get menu, delete menu and unload script. SO, what do I do with this thang?
EDIT: ok, I think I got it. I don't know what it is supposed to do but I think this is what I have.
PostPosted: Sun Dec 23, 2012 10:16 am  (#20)
yes, thats it. The program does basically nothing. It says, that you have a script that has two (I think, just one script loaded) menuentries. One in Filters/Alpha to Logo and one in script-fu/Logo. Both menuenties call the same script. The script is old, since, I think 2.6, the <Toolbox>/Xtns is not supported anymore and is mapped to <Image>/Filters. Do you really need both menu entries? If not, delete one. If yes, or the position of the entry is not good enough, drag/drop it to a position in the menutree, which is better for you desire. This is, what the program is good for: sorting the scripts to whereever YOU want. With more than one script, of course. You can drag your whole script-directory to the tree-window. The programm reads all scripts and creates something similar to what you see now. And now you can sort all of them to a convenient structure in your gimp-menu.
