It is currently Mon Oct 12, 2026 6:25 am
 Post subject: is it possible to have a fixed layermask ?
PostPosted: Tue Jan 15, 2013 10:51 pm  (#1)
this probably belongs to scripts....
is it possible to have the option of a fixed layermask ?
in GIMP a layer and its layermask are connected
if you move the layer, the mask moves as well
what i would like to have is a layermask that stays where it is, while i can move the belonging layer around as i wish
 Post subject: Re: is it posible to have a fixed layermask ?
PostPosted: Tue Jan 15, 2013 11:00 pm  (#2)
Hi Esper
I have run into this predicament myself and the closest thing I could get it to work was to select the whole canvas then hit Ctrl+C then Ctrl+V and move the floating layer. Then hit Ctrl+H to anchor it back. This is the way I move contents of layers that have masks. The shortcut keys make it a little easier.
Although you could actually choose the mask and move it then choose the layer canvas and move both back to where you want them.
Alan
 Post subject: Re: is it possible to have a fixed layermask ?
PostPosted: Tue Jan 15, 2013 11:15 pm  (#3)
Hi PegLeg,
interesting, i used the technique you described in the texture effect tutorial
http://gimpchat.com/viewtopic.php?f=23&t=5774
another idea is to use a saved channel
you can edit the opacity of the mask (and the color)
so lets say you create text on a transparent layer
alpha to select the text
save the selection to a channel and then turn up the opacity of the mask to 100%
in effect this will give you a (seemingly) black layer with your text in it
