It is currently Mon Oct 12, 2026 12:12 am
 Post subject: offset in pixel vs. angle
PostPosted: Mon Jan 21, 2013 2:41 am  (#1)
is there an easy way to calculate offset in pixels for a specific angle ?
for example, i want to offset an object by 135°
how much is that in pixels in the offset dialogue (Strg +O) ?
90 and 180° are pretty obivious, how about other angles ?
 Post subject: Re: offset in pixel vs. angle
PostPosted: Mon Jan 21, 2013 3:29 am  (#2)
I would use the Measurement tool
and then offset
PostPosted: Mon Jan 21, 2013 3:36 am  (#3)
If you are moving your object a distance D at an angle A then the you compute the x and y offsets with the following formula:
x = D * cos(A)
y = D * sin(A)
Where 'cos' and 'sin' are the mathematical cosine and sine functions respectively.
If you are writing a script or plug-in, you should be aware that the angle provided to the 'cos' and 'sin' functions are typically specified in radians, rather than degrees. To convert between radians and degrees, the following equation applies:
1 radian = 180 / π degrees
or
1 radian ≈ 57.3 degrees
PostPosted: Mon Jan 21, 2013 8:11 am  (#4)
thank you guys, will check that out later
